7.1.5 Call Manager Bus Ed - Services not starting
davidfield
Participant
Participant
We had an issue where the server effectively failed due to the Readonly file system issue with the IBM PLatform.  We applied the patch and rebooted and the server complained about the discs being out of sync and reporting file system readonly.  We re-synced the disks and the filesystem readoly error disappeared.  THe server starts and we get CLI, I can ping  the server and SSH onto the CLI.  But phones wont register nor web interfaces available.  From what I can see the services are all Starting but never reach the started phase.
Can anyone shed some light on why this would occur?
Thanks in advance
D
admin:
admin:utils service list
Requesting service status, please wait...
System SSH [STARTED]
Cluster Manager [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTED]
A Cisco DB Replicator[STARTED]
Cisco AMC Service[STARTING]
Cisco Audit Event Service[STARTING]
Cisco Bulk Provisioning Service[STARTING]
Cisco CAR Scheduler[STARTING]
Cisco CAR Web Service[STARTING]
Cisco CDP[STARTING]
Cisco CDP Agent[STARTING]
Cisco CDR Agent[STARTING]
Cisco CDR Repository Manager[STARTING]
Cisco CTIManager[STARTING]
Cisco CallManager[STARTING]
Cisco CallManager Admin[STARTING]
Cisco CallManager Cisco IP Phone Services[STARTING]
Cisco CallManager Personal Directory[STARTING]
Cisco CallManager Serviceability[STARTING]
Cisco CallManager Serviceability RTMT[STARTING]
Cisco Certificate Expiry Monitor[STARTING]
Cisco DRF Local[STARTING]
Cisco DRF Master[STARTING]
Cisco Database Layer Monitor[STARTED]
Cisco Dialed Number Analyzer[STARTING]
Cisco Extended Functions[STARTING]
Cisco Extension Mobility[STARTING]
Cisco Extension Mobility Application[STARTING]
Cisco IP Voice Media Streaming App[STARTING]
Cisco License Manager[STARTING]
Cisco Log Partition Monitoring Tool[STARTING]
Cisco RIS Data Collector[STARTING]
Cisco RTMT Reporter Servlet[STARTING]
Cisco SOAP - CDRonDemand Service[STARTING]
Cisco Serviceability Reporter[STARTING]
Cisco Syslog Agent[STARTING]
Cisco TAPS Service[STARTING]
Cisco Tftp[STARTING]
Cisco Tomcat[STARTING]
Cisco Tomcat Stats Servlet[STARTING]
Cisco Trace Collection Service[STARTING]
Cisco Trace Collection Servlet[STARTING]
Cisco Unified Mobile Voice Access Service[STARTING]
Connection Administration[STARTING]
Connection DB[STARTING]
Connection DB Event Publisher[STARTING]
Connection License Server[STARTING]
Connection SNMP Agent[STARTING]
Connection Server Role Manager[STARTING]
Connection Serviceability[STARTING]
Host Resources Agent[STARTING]
MIB2 Agent[STARTING]
Native Agent Adapter[STARTING]
SNMP Master Agent[STARTING]
SOAP -Log Collection APIs[STARTING]
SOAP -Performance Monitoring APIs[STARTING]
SOAP -Real-Time Service APIs[STARTING]
System Application Agent[STARTING]
Cisco AXL Web Service[STOPPED]  Service Not Activated
Cisco CTL Provider[STOPPED]  Service Not Activated
Cisco CallManager Attendant Console Server[STOPPED]  Service Not Activated
Cisco CallManager SNMP Service[STOPPED]  Service Not Activated
Cisco Certificate Authority Proxy Function[STOPPED]  Service Not Activated
Cisco DHCP Monitor Service[STOPPED]  Service Not Activated
Cisco DirSync[STOPPED]  Service Not Activated
Cisco IP Manager Assistant[STOPPED]  Service Not Activated
Cisco Messaging Interface[STOPPED]  Service Not Activated
Cisco UXL Web Service[STOPPED]  Service Not Activated
Cisco WebDialer Web Service[STOPPED]  Service Not Activated
Connection Access Layer[STOPPED]  Service Not Activated
Connection CM Database Event Listener[STOPPED]  Service Not Activated
Connection Conversation Manager[STOPPED]  Service Not Activated
Connection Database Proxy[STOPPED]  Service Not Activated
Connection Digital Networking Replication Agent[STOPPED]  Service Not Activated
Connection File Syncer[STOPPED]  Service Not Activated
Connection Groupware Caching Service[STOPPED]  Service Not Activated
Connection IMAP Server[STOPPED]  Service Not Activated
Connection Inbox RSS Feed[STOPPED]  Service Not Activated
Connection Integrated Mailbox Configuration[STOPPED]  Service Not Activated
Connection Message Event Service[STOPPED]  Service Not Activated
Connection Message Transfer Agent[STOPPED]  Service Not Activated
Connection Mixer[STOPPED]  Service Not Activated
Connection Notifier[STOPPED]  Service Not Activated
Connection Personal Communication Assistant[STOPPED]  Service Not Activated
Connection Realtime Monitoring APIs[STOPPED]  Service Not Activated
Connection Reports Data Harvester[STOPPED]  Service Not Activated
Connection SMTP Server[STOPPED]  Service Not Activated
Connection System Agent[STOPPED]  Service Not Activated
Connection Voice Mail Web Service[STOPPED]  Service Not Activated
Connection Voice Recognition Transport[STOPPED]  Service Not Activated
Connection Voice Recognizer[STOPPED]  Service Not Activated
Primary Node =true
>> Return code = 0
A Cisco DB[STARTED]
Cisco CDP[STARTING]
Primary Node =true
admin:
Anonymous
Not applicable
Once file system corruption is encountered by the system going read only or improper shutdown a rebuild must be done.
This is documented in the CUCM Release Notes:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/rel_notes/8_5_1/cucm-rel_notes-851.html
CSCth53322 Rebuild Server After You Use the Recovery Disk
After you use the recovery disk to bring a server with a corrupted file  system into a bootable and semi-functional state, Cisco recommends that  you rebuild the server.
Anonymous
Not applicable
Recognize Your Peers
