12-17-2013 07:02 AM - edited 03-16-2019 08:54 PM
Can someone please confirm and provide documentation about which CM versions the 7800 series is compatible with? According to the data sheet it is compatible with 8.5(1)+. However, devpacks aren't available for 9.1(1). Yet, the release notes for 7800 loads don't specify compatibility information.
Solved! Go to Solution.
12-18-2013 09:39 AM
Hi Gordon,
Gr8.
Can u share the show version active and registered 78xx phone ?
regds,
aman
03-23-2014 10:32 PM
Thanks, do you have any idea how many DLU is required for 7800 series phone as i can not find the same through License Unit calculator on CUCM v8.6
