05-09-2015 07:18 AM - edited 03-17-2019 02:56 AM
While connecting Cisco 7800 Series Phone on the Brocade Switches, this particular model phone not getting the IP Address from the DHCP and i have tried to given static IP address as well but its not reachable. But when i connect the other all model Phones Like 9xxxx series, 8xxx series and 79xxx will be working fine on the Same Port. But when i connect on Other Switches 78XX Series Phones getting registered with CUCM and its working perfectly.
05-11-2015 03:25 AM
Hi Sunish,
Based on the details provided it looks to be some sort of an issue with the communication between 78XX IP phone and Brocade switch. If you have a 78XX working fine on any other Brocade switch then you can take a capture for both the scenarios and they can be compared. Did you check with Brocade for any known issues?
Manish
05-11-2015 10:31 AM
Is the Brocade switch configured to use LLDP?
