Community Helping Community
314
Highlighted
Beginner
7821 ip phone issue in compare of 7911
I used to use 7911 ipphones and there wrere a good feature which i mention it dial auto complete , which when i press any no in key pad like 5 , screen showed me all dialed No that start with 5 . Unfortunatelly this feature has been removed in 7821 . Is there any way to enable it ?
Everyone's tags (1)
3 REPLIES 3
This feature is not available
This feature is not available on 78XX IP phones. You may check with TAC for any enhancement defects open for the same, else you can engage your Cisco acct team for a feature enhancement request.
Manish
Hall of Fame Community Legend
Hi there,
Hi there,
Just to add a note to the great info from my friend Manish (+5), it looks like there is a Bug/Enhancement request open for this issue that you can follow to see when it's fixed;
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuw53728
Auto dial feature to be implemented on 78xx series phones
CSCuw53728
Symptom:
When you pre-dial, your phone tries to anticipate the number you are dialling by displaying matching numbers (if available) from your Placed Calls log. This is called Auto Dial. This feature doesn't work with 78xx series phone. It works with 79xx phones though.
Conditions:
Cisco IP phone 78xx (any load)
Workaround:
n/a
Thanks Rob for sharing the
Thanks Rob for sharing the bug.
Manish
Content for Community-Ad
FusionCharts will render here
