7821 won't register from different vlan
tony.elrassy
Hello Guys,
we have bought 7821 SIP phones but unfortunately they wont register unless on they are on the subnet as the CME.(tested and they register normally)
i used session-transport tcp but the problem persists.
Below is my CME version, configuration and some debug voice register events and voice register errors outputs.
1-version
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.4(3)M2, RELEASE SOFTWARE (fc2)
2-Config info
voice service voip
ip address trusted list
ipv4 xxxx
ipv4 xxxx
ipv4 xxxx
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
registrar server expires max 600 min 60
voice register global
mode cme
source-address 172.28.128.130 port 5060
max-dn 200
max-pool 50
timezone 23
tftp-path flash:
create profile sync 3790102529458533
voice register dn  33
 number 7178
 mwi
voice register pool 33
busy-trigger-per-button 2
id mac F09E.636F.181A
type 7821
number 1 dn 33
cor incoming keyring-local default
presence call-list
dtmf-relay rtp-nte
description xxxx
codec g711ulaw
3-Debug output
VOICE_REG_POOL: Register request for (7178) from (x.x.x.x)
215996: *May 3 10:33:56.985: auth absent
215997: *May 3 10:33:56.985: VOICE_REG_POOL: key(B63BA7DC378763C6) added to nonce table
215998: *May 3 10:33:56.985: voice_reg_get_phone_index_from_contact: Trying to match key 7178
215999: *May 3 10:33:56.985: voice_reg_get_phone_index_from_contact:key MATCHED!!
216000: *May 3 10:33:56.997: VOICE_REG_POOL: Register request for (7178) from (x.x.x.x)
216001: *May 3 10:33:56.997: auth present
216002: *May 3 10:33:56.997: voice_reg_get_phone_index_from_contact: Trying to match key 7178
216003: *May 3 10:33:56.997: voice_reg_get_phone_index_from_contact:key MATCHED!!
216004: *May 3 10:33:57.013: VOICE_REG_POOL: Register request for (7178) from (x.x.x.x)
216005: *May 3 10:33:57.013: auth present
*May 3 10:47:30.737: voice_reg_get_reg_expires_timer: no voice register pool found
216063: *May 3 10:47:30.741: VOICE_REG_POOL: Contact doesn't match any pools
216064: *May 3 10:47:30.741: voice_reg_get_phone_index_from_contact: No contact list
216065: *May 3 10:47:30.753: voice_reg_get_reg_expires_timer: no voice register pool found
216066: *May 3 10:47:30.753: VOICE_REG_POOL: Contact doesn't match any pools
216067: *May 3 10:47:30.753: voice_reg_get_phone_index_from_contact: No contact list
216068: *May 3 10:47:30.765: voice_reg_get_reg_expires_timer: no voice register pool found
216069: *May 3 10:47:30.765: VOICE_REG_POOL: Contact doesn't match any pools
TR
For SIP phones to register from remote vlan, you need to configure authenticate register command under voice register global and configure username xxx pass xxx under your voice register pool. Try that and let us know the result.
Hello Mohammed,
Well it worked super fine! 10x
Hello again,
Well i have another issue with the same CME. The clock is not correct. I did put the timezone, however nothing is changing. can you help on this issue?
DL-VG(config-telephony)#time-z
DL-VG(config-telephony)#time-zone 22
DL-VG(config-telephony)#CREate cnf-files
Creating CNF files
CNF-FILES: Clock is not set or synchronized, retaining old versionStamps
Hello sir, I have similar problem router 4321 as call manager with dhcp phones 7821 work fine, but when try to use phones through another router connected to 4321 and using it as dhcp helper network is fine, phone take address and tftp address but not registering
