02-26-2019 01:55 PM
Hi All
Im trying to Auto Provision or Auto Register multiple 7841-3PCC phones using the attached config file. All the phones pick the same file to Auto Register, How do i name config so that each phone can download its config file from the TFTP server.
I have named the file 7841-3PCC.xml . This is file that all the phones are downloading and auto registers. If i change the file name to 7841-3PCC0CD0F8F429C8.xml for the 2nd phone to Auto Register, it fails to download it.
02-26-2019 04:05 PM
You have used
<Extension_1_ ua="na">5555</Extension_1_>
This is not supported. It has to be a number between 1 to 4 i.e. number of lines on the phone.
So for a 7841 -
Please upgrade to the latest firmware for MPP - 11.2.3MPP.398 which is available on cisco.com.
After this you can go to http://ipaddress/admin/cfg.xml
Here you will see the available options for all tags and configure accordingly.
Thanks.
02-26-2019 10:03 PM
02-27-2019 07:42 AM
Hello.
Did you change the tag values as mentioned in the previous reply? If yes, please send the modified xml.
I would need PRTs to see what exactly you are configuring on both phones.
Are you performing a resync on phone B with 7841-3PCCXXX.xml instead of 7841-3PCC.xml?
Thanks.
02-27-2019 07:54 AM
