7841 Cisco Device
Has anyone experience issues with 7841 IP phone not displaying the option to use call pickup or group pickup from this device. We are running CUCM 11.5; system version 11.5.1.17900-52 and vmware is installed.
We have several other models running and this feature works without issue on our other models. Any suggestions
George Sotiropoulos
You may need to check the following 2:
-Can you confirm if the Softkey Template of the 7841 includes the CallPickup and GrpPickup Softkeys?
-Can you check if the phone has the latest firmware?
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Thank for your reply;
Can you confirm if the Softkey Template of the 7841 includes the CallPickup and GrpPickup Softkeys? Yes, we created one with those attributes; changing the template to the custom template, restarting the device nothing changed.
-Can you check if the phone has the latest firmware? the firmware is 12.6
Also, all of our 7841 devices are not displaying this behavior they are functioning without issue; at present it appears to be about 12 devices or so that we are getting complaints.
Thank you for your time,
J
