01-22-2020 04:34 AM
Hi All,
Having an issue getting 7841 phones to register to a 4431 router in SRST, none of my phones register to the router when CUCM's are shutdown.
I have the following configuration;
voice service voip
ip address trusted list
ipv4 10.105.44.xxx
ipv4 10.105.44.xxx
rtp-port range 16384 32768
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 nse force version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
modem passthrough nse codec g711ulaw
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class h323 1
h225 timeout tcp establish 5
voice register global
default mode <-- mode srst not available, only mode esrst or mode cme
no allow-hash-in-dn
timeouts interdigit 5
system message Phone is in emergency mode
max-dn 20
max-pool 40
voice register pool 1
translation-profile incoming SRST-IN
id network 10.0.0.0 mask 255.0.0.0
dtmf-relay rtp-nte
voice-class codec 1
any help would be greatly appreciated!
Solved! Go to Solution.
01-23-2020 02:16 AM
01-22-2020 04:47 AM
My 7841 phones worked well with same configuration. I have two comments:
1) you have to choose mode east which is obvious
2) for voice register pool 1
Can you specify the specific subnet which exactly matches the IP Phone subnet, and you can create multiple pools instead of using one pool with big mask.
01-22-2020 06:29 AM
01-22-2020 09:46 AM
Sorry for that. Yes it is esrst :)
There is no option shown for simple srst under voice register global
01-23-2020 02:16 AM
01-23-2020 02:26 AM
Great!! How we forget to talk about it :)
