7841 registration issue on CUCM Business Edition 9.x
ctamburello
Beginner
Beginner
Hi all,
even if 7841 Cisco Data S. says 7841 is compaltible for
8.6.2
9.1.2
10.x and later
seems this is not true .
Actually 7841 works only with 10.x
Anyone Knows more about or has a solution ?
Best regards
CARLO
Suresh Hudda
Rising star
Rising star
Hi Carlo,
What is the actual problem you are facing with these phones ?
By the way, if you are not seeing the device type (7841) while adding it to cucm, then plz install latest device pack in cucm.
Suresh
It seems that 7841 does not have device pack for CUCM 9.X
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
There is for 9.1(x), if you're running 9.0(x), you won't find one, and you need to upgrade to a compatible release.
Cisco Unified IP Phone Feature and Cisco Unified Communications Manager Device Pack Compatibility Matrix
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
java
if this helps, please rate
You can find the latest device pack for 9.1.2 at below link.
http://software.cisco.com/download/release.html?mdfid=284510097&softwareid=282074299&release=9.1%281.21017%29&relind=AVAILABLE&rellifecycle=&reltype=all
Suresh
