11-06-2017 11:38 AM - edited 03-17-2019 11:33 AM
I have 2 sets of phones, 7821 & 7861. They are both registered at the same site. The 7821 phones work fine, but I have voice quality issues on external and incoming calls on 7861 phones.
Callers complain of receivers voice sounding robot-like. I don't think this is a qos issue, as 7821 phones don't have the same problem.
Anyone else experienced similar? Any advice much appreciated!
11-06-2017 03:55 PM
Are the phones registered to CUCM or CME? If CUCM, are they in the same device pool and using the same media resources? What happens if you swap a 7821 for 7861, does the problem follow the phone?
11-07-2017 05:15 AM
cucm. I dont have the issue with 7821.
11-06-2017 07:27 PM
11-07-2017 05:18 AM
11.7
12-05-2017 04:26 PM
I am having the exact same thing happening with my 7861 phone.
Users reporting robotic voice quality.
We are using CME 11.5 with Phone Firmware 11.5 for 7841 and 7861 on a Cisco ISR 2901 platform.
We are using G711ulaw across the board codec wise as this is necessary to support Cisco Unity Express on the 7841 and 7861.
12-06-2017 09:35 AM
Update: I upgraded all 7841 and 7861 phones to 11.7.1.17 and on the 7861 I am still experiencing the robotic voice issue, specifcally we are recording a prompt on the CUE Auto Attendant and it is sounding robotic when played back. It sounds like a bit of packlet loss, at some points the voice speeds up or pauses in the sentences are clipped. I also wanted to note that on the 7861 phone, it is connected at 100 Mbps with a PC plugged into the PC Port.
We are testing now on a 7841 to see if it is affecting this phone platform as well. The 7841 we are testing has a 1 Gbps link.
02-19-2019 10:33 PM
1) Please clarify if the issue is when you are recording CUE Prompt for for normal Phone to Phone calls as well.
02-19-2019 03:41 PM
