7906 IP Phones CME Registeration Issue
ali_ebrahimi
Hello Everybody
I have just received a Cisco 2951 that someone has formatted its flash. There is not CME files and directories on flash:/. I tried to load firmware for my 7906 phones. I tried to configure but Phones do not register. So, can anybody help me with my issue please.
My Configuration is as follows:
version 15.4
hostname Voip-Gateway
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/3
enable secret 5 $1$W2CC$tzqDrhNYNDkXcKm67mCHc.
no aaa new-model
clock timezone TEHRAN 3 30
crypto pki trustpoint TP-self-signed-3784079079
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3784079079
 revocation-check none
 rsakeypair TP-self-signed-3784079079
crypto pki certificate chain TP-self-signed-3784079079
 certificate self-signed 01
ip domain name rouhina.local
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
voice service voip
 allow-connections h323 to sip
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  registrar server expires max 600 min 60
voice register global
 mode  cme
 source-address 172.30.20.40 port 5060
 max-dn 100
 max-pool 150
 time-format 24
 tftp-path flash:
 create profile sync 0000921404335521
voice register dn  1
 number 8000
 shared-line
voice register pool  1
 id mac 0022.905A.6A88
 type 7906
 number 1 dn 1
license udi pid CISCO2951/K9 sn FGL2012101P
license boot module c2951 technology-package securityk9
license boot module c2951 technology-package uck9
hw-module pvdm 0/0
username admin secret 5 $1$C86.$yb/X37s4gx07hSSSsU3JT/
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 172.30.20.40 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.30.20.254
nls resp-timeout 1
cpd cr-id 1
tftp-server flash:/apps11.9-2-1TH1-13.sbn
tftp-server flash:/cnu11.9-2-1TH1-13.sbn
tftp-server flash:/cvm11sip.9-2-1TH1-13.sbn
tftp-server flash:/dsp11.9-2-1TH1-13.sbn
tftp-server flash:/jar11sip.9-2-1TH1-13.sbn
tftp-server flash:/SIP11.9-2-1S.loads
tftp-server flash:/term06.default.loads
tftp-server flash:/term11.default.loads
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
 shutdown
telephony-service
 no auto-reg-ephone
 max-ephones 150
 max-dn 100
 ip source-address 172.30.20.40 port 2000
 max-redirect 5
 cnf-file location flash:
 load 7906 term06.default
 time-format 24
 max-conferences 8 gain -6
 web admin system name admin secret 5 $1$iDOg$ys3wlaRG6u3div0Hnp3rM0
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone  1
 device-security-mode none
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login local
 transport input telnet
scheduler allocate 20000 1000
ntp server 172.30.20.200
The following are files I copied to flash
1  -rw-   104785228   Feb 8 2017 11:25:02 +03:30  c2951-universalk9-mz.SPA.154-3.M3.bin
   10  -rw-     3150897   Feb 8 2017 13:12:06 +03:30  apps11.9-2-1TH1-13.sbn
   13  -rw-      553375   Feb 8 2017 13:12:08 +03:30  cnu11.9-2-1TH1-13.sbn
   12  -rw-     2658264   Feb 8 2017 13:12:12 +03:30  cvm11sip.9-2-1TH1-13.sbn
   15  -rw-      356907   Feb 8 2017 13:12:14 +03:30  dsp11.9-2-1TH1-13.sbn
   14  -rw-     1619681   Feb 8 2017 13:12:16 +03:30  jar11sip.9-2-1TH1-13.sbn
   16  -rw-         674   Feb 8 2017 13:12:18 +03:30  SIP11.9-2-1S.loads
   11  -rw-         678   Feb 8 2017 13:12:18 +03:30  term06.default.loads
    6  -rw-         678   Feb 8 2017 13:12:18 +03:30  term11.default.loads
Suresh Hudda
Try to put below command under "voice register global" and check..
load 7906 SIP11.9-2-1S.loads
Suresh
Thank you for your response
I changed my settings to SCCP but now, phones wait a lot for Upgrading and shift to Cisco logo and restart a little later. No registration happens.
By the way, as I mentioned before, somebody has formatted flash: and all default file structure has ben deleted.
Ali
