ā04-25-2013 04:08 AM - edited ā03-16-2019 04:59 PM
Hi all,
7911 is registering endlesslly.
It holds on:
Apr 25 12:54:59.651 CDT: TFTP: Looking for CTLSEPD824BDBA2483.tlv
Apr 25 12:54:59.731 CDT: TFTP: Looking for ITLSEPD824BDBA2483.tlv
Apr 25 12:54:59.811 CDT: TFTP: Looking for ITLFile.tlv
Apr 25 12:55:00.079 CDT: TFTP: Looking for SEPD824BDBA2483.cnf.xml
Apr 25 12:55:00.083 CDT: TFTP: Opened flash:/its/vrf1/XMLDefault7911.cnf.xml, fd 9, size 1286 for process 187
Apr 25 12:55:00.087 CDT: TFTP: Finished flash:/its/vrf1/XMLDefault7911.cnf.xml, time 00:00:00 for process 187
Apr 25 12:55:04.111 CDT: TFTP: Looking for English_United_States/tc-sccp.jar
Apr 25 12:55:07.363 CDT: TFTP: Looking for United_States/g3-tones.xml
and it stops...
my tftp-bindings:
tftp-server flash:/its/united_states_7960-tones.xml alias United_States/7960-tones.xml
tftp-server flash:/its/united_states_7960-font.xml alias English_United_States/7960-font.xml
tftp-server flash:/its/united_states_7960-font.xml alias English_United_States/7920-font.xml
tftp-server flash:/its/united_states_7960-dictionary.xml alias English_United_States/7960-dictionary.xml
tftp-server flash:/its/united_states_7960-kate.xml alias English_United_States/7960-kate.xml
tftp-server flash:/its/united_states_7960-kate.xml alias English_United_States/7920-kate.xml
tftp-server flash:/its/united_states_SCCP-dictionary.xml alias English_United_States/SCCP-dictionary.xml
tftp-server flash:/jar11sccp.9-2-3TH1-9.sbn alias jar11sccp.9-2-3TH1-9.sbn
tftp-server flash:/cnu11.9-2-3TH1-9.sbn alias cnu11.9-2-3TH1-9.sbn
tftp-server flash:/apps11.9-2-3TH1-9.sbn alias apps11.9-2-3TH1-9.sbn
tftp-server flash:/dsp11.9-2-3TH1-9.sbn alias dsp11.9-2-3TH1-9.sbn
tftp-server flash:/cvm11sccp.9-2-3TH1-9.sbn alias cvm11sccp.9-2-3TH1-9.sbn
tftp-server flash:/SCCP11.9-2-3S.loads alias SCCP11.9-2-3S.loads
tftp-server flash:/its/vrf1/XMLDefault7911.cnf.xml alias SEPD824BDBA2483.cnf.xml
tftp-server flash:/its/SEPDEFAULT.cnf alias SEPDefault.cnf
tftp-server flash:/its/vrf1/XMLDefault.cnf.xml alias XMLDefault.cnf.xml
tftp-server flash:/its/vrf1/ATADefault.cnf.xml alias ATADefault.cnf.xml
my config:
telephony-service
max-ephones 24
max-dn 48
ip source-address 172.16.100.1 port 2000
cnf-file location flash:
load 7911 SCCP11.9-2-3S.loads
time-zone 23
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Apr 25 2013 12:58:12
ephone-dn 10 dual-line
number 1000
ephone 10
device-security-mode none
mac-address D824.BDBA.2483
type 7911
button 1:10
What could be the issue?
GN
ā04-25-2013 04:33 AM
Have you verified the firmware directory in flash? Have you verified that you have the correct firmware, you put ".loads" I think it should be ".sbin". Verify your tftp and alias are correct.
Yosh
ā04-25-2013 04:53 AM
Have you verified that you have the correct firmware.
how can I verify that?
I have do this aliases by myself?
GN
ā04-25-2013 04:58 AM
hello
you can verify from Cisco site by using the below link for 79xx phones
http://software.cisco.com/download/navigator.html?mdfid=269065653&catid=278875240
Please try the my below post , i think this is the issue.
Thank you
please rate if this will help
ā04-25-2013 04:45 AM
Hello
please try the below without extension
telephony-service
no create-cnf
create-cnf
thank you
ā04-25-2013 05:29 AM
I have download new firmware:
cmterm-7911_7906-sccp.9-3-1SR2-1.zip
I have unzipped it and copied one by one file to router flash.
Then I have restarted my 7911.
And no matter if I have:
load 7911 SCCP11.9-3-1SR2-1S
or
load 7911 SCCP11.9-3-1SR2-1S.loads
my 7911 still is registering endlessly at:
Apr 25 14:19:43.887 CDT: TFTP: Looking for English_United_States/tc-sccp.jar
Apr 25 14:19:45.095 CDT: TFTP: Looking for United_States/g3-tones.xml
should I have this additionl tftp bindings?
GN
ā04-25-2013 05:40 AM
Hello
Please you have to use the command under telephony-service without .loads. Then under telephony-service no create cnf create cnf
Thank you
ā04-25-2013 06:22 AM
Still no luck...
My settings are (cnf recreated):
telephony-service
max-ephones 24
max-dn 48
time-zone 23
create cnf-files version-stamp 7960 Apr 25 2013 15:18:33
On my 7911 in right upper corner shows 1000 while my numer configuration is:
number 999
ephone 10
type 7911
GN
ā04-25-2013 06:57 AM
hello
can you delete ephone 10 , and remove the phone from your network .After that readd ephone 10 then add the phone
to your netwrok .
did you do no create cnf then create cnf?. I do not see button 1:10 under ephone 10 configuration , please clarrify
Thank you
ā04-25-2013 10:27 AM
try putting the button 1:10 , under ephone 10
ā04-26-2013 12:48 AM
Still no luck,
my actual settings:
telephony-service
max-ephones 24
max-dn 48
time-zone 23
create cnf-files version-stamp 7960 Apr 26 2013 09:22:42
ephone-dn 10
number 999
name test
ephone 10
type 7911
button 1:10
and my telephone - why he has such date and time when on my CME is
#sh clock
09:47:55.503 CDT Fri Apr 26 2013
ā04-26-2013 02:20 AM
Hi Grzegorz niecka,
check with factory default setting.
1. check DHCP : enable ( If your network DHCP enabled)
2. Power off the phone
3. Power on and hold # key for few seconds.
4. Led's are blinking then press 123456789*0#
5. It will restart and upgrade with your tftp server settings
ā04-26-2013 03:08 AM
Have do it before - after hard reset telephone upgrades its software but at the end still get registering...
ā04-26-2013 03:10 AM
I have TAC webex.
Durning webex when we have shutdown/no shutdown telepgoney service error message appears:
%SKINNYSERVER-3-NOINIT: Can't initialize Skinny server
they suggest me to try on lower IOS version - I have tried and still I get this message.
ā04-26-2013 08:07 AM
Hi Grzegorz
Try delete the CTL file,
Settings > Security > Trust List > ITL File > **# (to unlock the settings) > Erase
Cheers
Bruno Rangel
please rate if this help
