7911 please help
fcatalao
Having difficulty with 7911 logo/backround images.
I have read in forum that the List.xml file is case sensitive and I am sure I have correctly filled in the file.
The png files have been correctly converted and that they are in correct directories.
I have restarted the tftp and resetted the phones.
The configuration we have is CCM4.1.3 and 8-3-4SR1 firmware in 7911 phones.
I am ready to pull my hair out with this and would appreciate any help.
FC
5 Replies 5
fcatalao
any help?
Just so we're on the same page here, what directory are the 7911 images in? What directory are your other background images in? What does your list.xml file look like?
Steve
Thanks for your reply.
Directory:
C:\Program Files\Cisco\TFTPPath\Desktops\95x34x1
List.xml:
FTP:Desktops/95x34x1/TN-Santogal.png”
URL=”TFTP:Desktops/95x34x1/Santogal.png” />
and files are:
thanks
fernando
Are the phones getting the updated list.xml file? i.e. can I see choices of images but no thumbails? Or am I not even getting any choices of images to use for my background?
Also - Where is the List.xml file located?
Have you given proper permissions to the new Desktops\95x34x1 directory that you created?
Steve
yes, Desktops\95x34x1 has proper permissions (user\CCMService)and phone cannot see any images.
thanks
