7914 Expansion Module - AUX/RJ11/RS232 Cable
gbljoba
I have a spare 7914 that i need to get running in the lab, Ive found the PSU but i cannot find the aux/rj11/rs232 cable that came with it. Does anyone know the spec? i.e straight cable or?
Jon
shaunswales
I've got spare 7914's, just had a look at one of the cables, straight through
You can just make up your own RJ11 with straight through specs.
black, red, black, green, blue, white, although it doesn't matter in the case of straight through.....
Good Luck!
Also, cable is around 15cm long
Please rate if this helps
