09-03-2015 06:53 AM - edited 03-17-2019 04:12 AM
I have (2) 7915 modules attached to a 7962 base. The 7915 modules started to go into a rebooting loop. They just keep rebooting. We have powered off the base and modules then re powered them up but the issue continues.
Looking for suggestions.
thanks
Ron
09-03-2015 11:42 AM
Hi Ron,
It seems that either 7915 doesn't get firmware file or it is not appropriate with call agent. Can you please share information where you are registering 7962/7915 ? is it CUCM or CME ? What version it is running along with firmware version of 7915?
Thanks!
Kunal
09-03-2015 11:45 AM
Is this CME or CUCM deployment? Is the phone rebooting as well or only the module? Can we get traces or debugs to see the errors.
10-06-2015 06:43 AM
I had this same problem. It was related to bug CSCuu49765. In order to fix it, TAC had to send me the latest engineering special firmware. At first they sent me ES5 however that did not fix the problem. They then sent me ES13 and this resolved the issue. The modules no longer reboot.
11-26-2015 01:54 PM
