7915 not loading firmware
gregniemeyer
I have two 7915 attached to a 7975.  I have set up a 7914...so I am familiar with the steps involved with setup.  Phone is running SCCP75.9-2-1S.  Firmware on CUCM for 7915 is B015-1-0-4-2.  If I select the IP of the phone from CUCM to bring up the web interface....neither expansion module has firmware loaded.
Greg
Manish Gogna
Hi Greg,
Can you try specifying the Phone Load info for 7915's on the 7975 configuration page ( Expansion Module Info ) and reset the phone and test again ( pic attached ).
Manish
Figured this out.  I was setting this up at a remote site.  Drove over to find the power was disconnected.  The thing that made this difficult.....when I first started configuring....the device had power.  Bad luck on my part that it came disconnected while configuring.
