Showing results forĀ
Search instead forĀ
Did you mean:Ā
7925G-EX NFPA
jlarmer23
We need to know if the 7925G-EX meets NFPA Class I/Div 2 and Class II/Div 2 requirements.
Usually you'll find the compliance in the data sheet in certificate and compliance section.have a look here for 7925-Ex data sheet. NFPA directly isnt there but CSA is there.If you can work out something from there.Some rules and regulations are interoperable I've read in the past.Hopefully you'll get an straight answer from someone
other thing to note is that 7925 phones are now EOS see here .If you are planning to buy new.you might want to look at 8821-EX
Cheers
Prabath
***Please rate all the useful posts***
-Prabath
