7925g Support cisco 1841 CME router
shaikh ibrahim
             Hi ,
                        Is  7925g Support cisco 1841 CME router ... i found type only 7920 and 7921 in the router.
any help will be higly appreciated
8 Replies 8
Leonardo Santana
What is the CME Version that you are using?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Hi , How can verify the CME version .. actually i got router and its mentioned there C1861-SRST-C-F/K9
With the following command:
sh telephony-service
CONFIG (Version=7.1)
Version 7.1
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
Leonardo Santana
Rate this if helps!
Leonardo Santana
Leonardo Santana
Other thing take a look on the datasheet of 7925g
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps9900/data_sheet_c78-504890.html
Protocol support
• Skinny Client Control Protocol (SCCP)
• Cisco Unified Communications Manager Versions 4.1, 4.2, 4.3, 5.1, 6.0, 6.1, 7.0 and later
• Cisco Unified Communications Manager Express Version 4.3 and later
• Cisco Unified Survivable Remote Site Telephony (SRST) Version 4.3 and later
Look too at the CME compatibility Matrix according to your version:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_device_support_tables_list.html
Rate this if helps!
Leonardo Santana
Leonardo Santana
Router#sh telephony-service
CONFIG (Version=4.2(0))
Version 4.2(0)
www.cisco.com/univercd/cc/td/doc/product/ac
source-address 0.0.0.0 port 2000
max-ephones 12
max-dn 24
max-conferences 4 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 5
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US   (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
Version 4.2(0)
www.cisco.com/univercd/cc/td/doc/product/ac source-address 0.0.0.0 port 2000
max-ephones 12
max-dn 24
dspfarm units 0
conference software
max-redirect 5
Hi , The CME 4.0 .. that  means it no t supported with this version ???  ho we can overcome this issue ??
Hello Shaikh
No its not support with your CME Version:
Version 4.2(0)
The 7925g is supported since CME Version 4.3 and Later:
Protocol support
Leonardo Santana
Leonardo Santana
Hi ,
      Can i upgrade CME 4.02 to later ... free of cost ??  thankyou in advance
