7937G
AntalVincz
Hi all,
How to format Cisco 7937G file system? (example other Cisco phone 3491672850*#)
What is the process?
The bootloader is retained?
Thank you!
Tony
Suresh Hudda
To perform a factory reset, press the Applications button, and then press **1.
When you perform a factory reset of the conference station, the following information is erased or reset to its default value:
LSC—Erased
User configuration settings—Reset to default values
Network configuration settings—Reset to default values
Call histories—Erased
Locale information—Reset to default values
Conference station application—Erased (conference station recovers by loading the term70.default.loads file or the term71.default.loads file, depending on the conference station model)
Before you perform a factory reset, ensure that the following conditions are met:
The conference station must be on a DHCP-enabled network.
A valid TFTP server must be set in DCHP option 150 or option 66 on the DHCP server.
The term70.default.loads file or the term71.default.loads file and the files specified in that file should be available on the TFTP server that is specified by the DHCP packet.
Suresh
Thank You!
This was carried out.
But unfortunately it did not resolve the problems.
How can I change the phone language into English?
I have only this file is available to me: apps37sccp.1-4-1-0.bin
Tony
