05-06-2009 06:50 PM - edited 03-15-2019 05:53 PM
I would like to remotely configure the Speed/Duplex of a 7940 or 7960. How are you guys doing this?
Thanks in advance,
Col
Solved! Go to Solution.
05-06-2009 10:47 PM
From IP Phone manually, no remote, you do have the option to configure the switch ports to 100 full and the phones should auto negotiate at 100 full if the ports on the switch are at 100 full.
05-06-2009 10:47 PM
05-07-2009 12:50 AM
Thanks for the quick reply.
I have read a couple of things that pointed towards TELNET (SIP only I think), SSH for SCCP (my test phone responds to SSH but I do not know the default username/password) or can it be done by editing the configuration file that the Phone TFTP's when it starts up. I take your response to mean that none of these are really options.
Thanks again and regards,
Col
