05-20-2011 02:58 AM - edited 03-16-2019 05:03 AM
I would like to add another menu (Corporate GSM List) under Services. Is there a way to do it?
Best Regards.
05-20-2011 06:51 AM
What CUCM or CME version are you running?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
05-20-2011 09:20 AM
I am not familiar with this IP Phones so would you please tell me how to identify CME or CUCM versions??Is it something that I can check it on the phone?
Best Regards.
