Highlighted
Beginner
Beginner
7940g Sip upgrade
I have bunch of Cisco 7940g phones I would like to upgrade to from Sccp to Sip. I have managed to upgrade some phones with no problem, but others I have failed to upgrade. I have the the right software from cisco which I have used to upgrade the working ones, BUT there seems to be a problem on the phones. The notable thing on the phones that cannot be upgraded it that when you press settings there is a limited amount of options compared with the the ones that I was able to upgrade. the only options available are ,Contrast,Ringtype,Network Configuration and Status. Where as there successfully phones have many other options. I also note that on LCD Copyright is 2000. where on the sucessfull phones it states 2000-2007.
I have tried different images from ver 3 to ver 8 but I still come out empty. Below is the log file from Tftpd32 log for the unsuccessful phones. I have also tried renaming the files to to match the ones below with error CREATE file but no luck. and Suggestions.
Freeing item 10.10.10.140 00:1D:A2:3E:AA:1B [09/07 15:39:46.218]
Message truncated (length was 8) [09/07 15:39:46.218]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:1D:A2:3E:AA:1B [09/07 15:40:34.750]
Client requested address 0.0.0.117 [09/07 15:40:34.750]
DHCP: proposed address 10.10.10.140 [09/07 15:40:34.781]
5432 Request 2 not processed [09/07 15:40:34.781]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1D:A2:3E:AA:1B [09/07 15:40:34.796]
Previously allocated address 10.10.10.140 acked [09/07 15:40:34.796]
5432 Request 2 not processed [09/07 15:40:34.796]
Connection received from 10.10.10.140 on port 50441 [09/07 15:40:40.281]
Read request for file <OS79XX.TXT>. Mode octet [09/07 15:40:40.281]
Using local port 1604 [09/07 15:40:40.312]
<OS79XX.TXT>: sent 1 blk, 15 bytes in 0 s. 0 blk resent [09/07 15:40:40.328]
Connection received from 10.10.10.140 on port 50442 [09/07 15:40:40.562]
Read request for file <SEP001DA23EAA1B.cnf.xml>. Mode octet [09/07 15:40:40.562]
File <SEP001DA23EAA1B.cnf.xml> : error 2 in system call CreateFile The system cannot find the file specified. [09/07 15:40:40.562]
Connection received from 10.10.10.140 on port 50443 [09/07 15:40:40.562]
Read request for file <XMLDefault.cnf.xml>. Mode octet [09/07 15:40:40.562]
File <XMLDefault.cnf.xml> : error 2 in system call CreateFile The system cannot find the file specified. [09/07 15:40:40.578]
Connection received from 10.10.10.140 on port 50444 [09/07 15:40:40.578]
Read request for file <SEP001DA23EAA1B.cnf>. Mode octet [09/07 15:40:40.578]
File <SEP001DA23EAA1B.cnf> : error 2 in system call CreateFile The system cannot find the file specified. [09/07 15:40:40.578]
Connection received from 10.10.10.140 on port 50445 [09/07 15:40:40.578]
Read request for file <SEPDefault.cnf>. Mode octet [09/07 15:40:40.578]
File <SEPDefault.cnf> : error 2 in system call CreateFile The system cannot find the file specified. [09/07 15:40:40.578]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 00:1D:A2:3E:AA:1B [09/07 15:41:33.343]
Client requested address 0.0.0.117 [09/07 15:41:33.359]
DHCP: proposed address 10.10.10.140 [09/07 15:41:33.359]
5432 Request 2 not processed [09/07 15:41:33.359]
Rcvd DHCP Rqst Msg for IP 0.0.0.0, Mac 00:1D:A2:3E:AA:1B [09/07 15:41:33.359]
Previously allocated address 10.10.10.140 acked [09/07 15:41:33.359]
Connection received from 10.10.10.140 on port 50447 [09/07 15:41:38.859]
Read request for file <OS79XX.TXT>. Mode octet [09/07 15:41:38.875]
Using local port 1609 [09/07 15:41:38.875]
<OS79XX.TXT>: sent 1 blk, 15 bytes in 0 s. 0 blk resent [09/07 15:41:38.875]
Connection received from 10.10.10.140 on port 50448 [09/07 15:41:39.109]
Read request for file <SEP001DA23EAA1B.cnf.xml>. Mode octet [09/07 15:41:39.109]
File <SEP001DA23EAA1B.cnf.xml> : error 2 in system call CreateFile The system cannot find the file specified. [09/07 15:41:39.109]
Connection received from 10.10.10.140 on port 50449 [09/07 15:41:39.125]
Read request for file <XMLDefault.cnf.xml>. Mode octet [09/07 15:41:39.125]
File <XMLDefault.cnf.xml> : error 2 in system call CreateFile The system cannot find the file specified. [09/07 15:41:39.125]
Connection received from 10.10.10.140 on port 50450 [09/07 15:41:39.125]
Read request for file <SEP001DA23EAA1B.cnf>. Mode octet [09/07 15:41:39.125]
File <SEP001DA23EAA1B.cnf> : error 2 in system call CreateFile The system cannot find the file specified. [09/07 15:41:39.125]
Connection received from 10.10.10.140 on port 50451 [09/07 15:41:39.125]
Read request for file <SEPDefault.cnf>. Mode octet [09/07 15:41:39.125]
File <SEPDefault.cnf> : error 2 in system call CreateFile The system cannot find the file specified. [09/07 15:41:39.125]
1 REPLY 1
Highlighted
Hall of Fame Master
Content for Community-Ad
