7941 Placed Calls
madelaporte
I have a bunch of 7941's running off a 2811/CME combo. I've got it all working nicely, but something that's been bugging my users is the placed calls.
Right now, when you navigate to the placed calls directory, all the entries are "Unknown Number"(unless it's an internal extension, or a number in one of the set directories), if i hit dial, i just get a dialtone, if i hit details, all i see is a blank To: line.
If there something i need to do to allow the phone to save the numbers it's dialled?
Miche
paolo bevilacqua
Hi, this is a bug and you need to upgrade IOS. Recommended is either 12.4(11)XJ4, or 12.4(11)XW6.
