7945 not working after reset on CME 8.5
akhundbilal
Hi, I have setup CME 8.5 on cisco 2851 router, 7911 is working fine , but when i tried to configure 7945 it does not work, it taked ip goes to find term45 but simply shows downloading but within 5 sec goes to blank screen .
here is the TFTP loggs
*Jun 7 03:52:05.054: TFTP: Server request for port 50212, socket_id 0x4B21E6C8 for process 329
*Jun 7 03:52:05.054: TFTP: read request from host 192.168.1.23(50212) via Vlan60
*Jun 7 03:52:05.054: TFTP: Looking for term45.default.loads
*Jun 7 03:52:05.058: TFTP: Opened flash:term45.default.loads, fd 0, size 654 for process 329
*Jun 7 03:52:05.058: TFTP: Sending block 1 (retry 0), socket_id 0x4B21E6C8
*Jun 7 03:52:05.058: TFTP: Received ACK for block 1, socket_id 0x4B21E6C8
*Jun 7 03:52:05.058: TFTP: Sending block 2 (retry 0), socket_id 0x4B21E6C8
*Jun 7 03:52:05.062: TFTP: Received ACK for block 2, socket_id 0x4B21E6C8
*Jun 7 03:52:05.062: TFTP: Finished flash:term45.default.loads, time 00:00:00 for process 329
*Jun 7 03:52:09.674: TFTP: Server request for port 52896, socket_id 0x4B21E6C8 for process 329
*Jun 7 03:52:09.674: TFTP: read request from host 192.168.1.23(52896) via Vlan60
*Jun 7 03:52:09.678: TFTP: Looking for term45.default.loads
*Jun 7 03:52:09.678: TFTP: Opened flash:term45.default.loads, fd 0, size 654 for process 329
*Jun 7 03:52:09.678: TFTP: Sending block 1 (retry 0), socket_id 0x4B21E6C8
*Jun 7 03:52:09.682: TFTP: Received ACK for block 1, socket_id 0x4B21E6C8
*Jun 7 03:52:09.682: TFTP: Sending block 2 (retry 0), socket_id 0x4B21E6C8
*Jun 7 03:52:09.682: TFTP: Received ACK for block 2, socket_id 0x4B21E6C8
*Jun 7 03:52:09.682: TFTP: Finished flash:term45.default.loads, time 00:00:00 for process 329
here is the files in flash:
flash:128MB.sdf
flash:CME_GUI_README.TXT
flash:S00105000400.sbn
flash:SCCP41.9-1-1SR1S.loads
flash:SCCP11.8-5-4S.loads
flash:SCCP42.9-3-1SR2-1S.loads
flash:SCCP42.8-3-3S.loads
flash:SCCP45.9-3-1-1S.loads
flash:SCCP45.8-5-4S.loads
flash:SIP45.9-4-2SR3-1S.loads
flash:admin_user.js
flash:admin_user.html
flash:apps41.9-1-1TH1-16.sbn
flash:apps11.8-5-4TH1-6.sbn
flash:apps42.9-3-1ES13.sbn
flash:apps42.8-3-2-27.sbn
flash:apps45.9-1-1TH1-16.sbn
flash:apps45.8-5-4TH1-6.sbn
flash:apps45.9-4-2ES26.sbn
flash:apps45.9-3-1TH2-5.sbn
flash:cnu11.8-5-4TH1-6.sbn
flash:c2800nm-ipvoicek9-mz.151-4.M9.bin
flash:cnu42.8-3-2-27.sbn
flash:cnu41.9-1-1TH1-16.sbn
flash:cnu45.8-5-4TH1-6.sbn
flash:cnu42.9-3-1ES13.sbn
flash:cnu45.9-4-2ES26.sbn
flash:cnu45.9-3-1TH2-5.sbn
flash:cvm11sccp.8-5-4TH1-6.sbn
flash:common.tar
flash:cvm42sccp.8-3-2-27.sbn
flash:cvm41sccp.9-1-1TH1-16.sbn
flash:cvm45sccp.8-5-4TH1-6.sbn
flash:cvm42sccp.9-3-1ES13.sbn
flash:cvm45sip.9-4-2ES26.sbn
flash:cvm45sccp.9-3-1TH2-5.sbn
flash:dom.js
flash:dsp41.9-1-1TH1-16.sbn
flash:dsp11.8-5-4TH1-6.sbn
flash:dsp42.9-3-1ES13.sbn
flash:dsp42.8-3-2-27.sbn
flash:dsp45.9-3-1TH2-5.sbn
flash:dsp45.8-5-4TH1-6.sbn
flash:ephone_admin.html
flash:dsp45.9-4-2ES26.sbn
flash:flashflash:es.tar
flash:home.tarflash:home.shtml
flash:jar31sccp.9-2-1TH1-13.sbn
flash:jar11sccp.8-5-4TH1-6.sbn
flash:jar42sccp.8-3-2-27.sbn
flash:jar41sccp.9-1-1TH1-16.sbn
flash:jar45sccp.8-5-4TH1-6.sbn
flash:jar42sccp.9-3-1ES13.sbn
flash:jar45sip.9-4-2ES26.sbn
flash:jar45sccp.9-3-1TH2-5.sbn
flash:normal_user.html
flash:sdm.tarflash:normal_user.js
flash:sxiconad.gifflash:start1
flash:term06.default.loads
flash:telephony_service.html
flash:term31.default.loads
flash:term11.default.loads
flash:term42.default.loads
flash:term41.default.loads
flash:term61.default.loads
flash:term65.default.loads
flash:term62.default.loads
flash:vlan.dat
flash:xml.template
flash:xml-test.html
here is the running config .
hostname Router
boot-start-marker
boot system flash:c2800nm-ipvoicek9-mz.151-4.M9.bin
boot-end-marker
enable password Basil003
no aaa new-model
clock timezone GMT 5 0
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp binding cleanup interval 600
ip dhcp excluded-address 192.168.1.200 192.168.1.254
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.1.240 192.168.1.254
ip dhcp excluded-address 192.168.1.200 192.168.1.210
ip dhcp excluded-address 192.168.1.1 192.168.1.20
ip dhcp excluded-address 192.168.1.230 192.168.1.239
ip dhcp excluded-address 192.168.1.100 192.168.1.199
ip dhcp pool ITS
network 192.168.1.0 255.255.255.0
option 150 ip 192.168.1.250
default-router 192.168.1.1 255.255.255.0
dns-server 192.168.1.250
ip dhcp pool voice
network 172.16.1.0 255.255.255.0
default-router 172.16.1.250 255.255.255.0
ip dhcp update dns
no ip domain lookup
no ipv6 cef
trunk group FXO
trunk group MOB
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
registrar server expires max 3600 min 3600
no call service stop
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 3
voice class dualtone-detect-params 1
freq-max-deviation 25
cadence-variation 20
voice class custom-cptone PKcus
dualtone reorder
frequency 435 485
cadence 352 260
dualtone disconnect
frequency 650 700
voice translation-rule 1
rule 1 /38899000/ /0/
rule 2 /38899001/ /0/
rule 3 /38899002/ /0/
rule 4 /38899003/ /0/
rule 5 /38899004/ /0/
rule 6 /38899005/ /0/
rule 7 /38899006/ /0/
rule 8 /38899007/ /0/
rule 9 /38899008/ /0/
rule 10 /38899009/ /0/
voice translation-rule 2
rule 1 /^7\(.+\)/ /\1/
voice translation-profile remove_prefix
translate called 2
voice translation-profile sip_incoming
translate called 1
voice-card 0
license udi pid CISCO2851 sn FHK1108F0NM
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed 100
interface FastEthernet0/1/0
switchport voice vlan 60
no ip address
interface FastEthernet0/1/1
switchport mode trunk
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
switchport access vlan 10
no ip address
interface Vlan1
no ip address
interface Vlan10
ip address 172.16.1.250 255.255.255.0
interface Vlan60
ip address 192.168.1.250 255.255.255.0
ip forward-protocol nd
ip http server
no ip http secure-server
ip route 43.242.100.0 255.255.255.0 10.24.40.29
ip route 172.16.1.0 255.255.255.0 192.168.1.251
snmp-server community public RO
tftp-server flash:apps11.9-1-1TH1-16.sbn
tftp-server flash:cnu11.9-1-1TH1-16.sbn
tftp-server flash:cvm11sccp.9-1-1TH1-16.sbn
tftp-server flash:dsp11.9-1-1TH1-16.sbn
tftp-server flash:jar11sccp.9-1-1TH1-16.sbn
tftp-server flash:SCCP11.9-1-1SR1S.loads
tftp-server flash:term06.default.loads
tftp-server flash:term11.default.loads
tftp-server flash:apps41.9-1-1TH1-16.sbn
tftp-server flash:cnu41.9-1-1TH1-16.sbn
tftp-server flash:cvm41sccp.9-1-1TH1-16.sbn
tftp-server flash:dsp41.9-1-1TH1-16.sbn
tftp-server flash:jar41sccp.9-1-1TH1-16.sbn
tftp-server flash:SCCP41.9-1-1SR1S.loads
tftp-server flash:term41.default.loads
tftp-server flash:term61.default.loads
tftp-server flash:cnu31.9-2-1TH1-13.sbn
tftp-server flash:cvm31sccp.9-2-1TH1-13.sbn
tftp-server flash:dsp31.9-2-1TH1-13.sbn
tftp-server flash:jar31sccp.9-2-1TH1-13.sbn
tftp-server flash:SCCP31.9-2-1S.loads
tftp-server flash:term31.default.loads
tftp-server flash:cnu42.8-3-2-27.sbn
tftp-server flash:cvm42sccp.8-3-2-27.sbn
tftp-server flash:dsp42.8-3-2-27.sbn
tftp-server flash:jar42sccp.8-3-2-27.sbn
tftp-server flash:SCCP42.8-3-3S.loads
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:apps42.9-3-1ES13.sbn
tftp-server flash:cnu42.9-3-1ES13.sbn
tftp-server flash:cvm42sccp.9-3-1ES13.sbn
tftp-server flash:dsp42.9-3-1ES13.sbn
tftp-server flash:jar42sccp.9-3-1ES13.sbn
tftp-server flash:SCCP42.9-3-1SR2-1S.loads
tftp-server flash:apps11.8-5-4TH1-6.sbn
tftp-server flash:cnu11.8-5-4TH1-6.sbn
tftp-server flash:cvm11sccp.8-5-4TH1-6.sbn
tftp-server flash:dsp11.8-5-4TH1-6.sbn
tftp-server flash:jar11sccp.8-5-4TH1-6.sbn
tftp-server flash:SCCP11.8-5-4S.loads
tftp-server flash:apps45.8-5-4TH1-6.sbn
tftp-server flash:cnu45.8-5-4TH1-6.sbn
tftp-server flash:cvm45sccp.8-5-4TH1-6.sbn
tftp-server flash:dsp45.8-5-4TH1-6.sbn
tftp-server flash:jar45sccp.8-5-4TH1-6.sbn
tftp-server flash:SCCP45.8-5-4S.loads
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
control-plane
voice-port 0/2/0
connection plar opx 0
caller-id enable
voice-port 0/2/1
caller-id enable
voice-port 0/2/2
caller-id enable
voice-port 0/2/3
trunk-group FXO
caller-id enable
voice-port 0/3/0
trunk-group FXO
caller-id enable
voice-port 0/3/1
trunk-group FXO
caller-id enable
voice-port 0/3/2
trunk-group FXO
caller-id enable
voice-port 0/3/3
trunk-group MOB
caller-id enable
mgcp profile default
dial-peer cor custom
name Mobile
name Local
name NWD
name Int
name UAN
name Toll
name Local-BR
name All
name internal
name Mobile-GSM
dial-peer cor list Level3
member Mobile
member Local
member UAN
member Toll
dial-peer cor list All
member All
dial-peer cor list internal
member internal
dial-peer cor list Mobile-GSM
member Mobile-GSM
member Mobile
dial-peer cor list Local
member Local
dial-peer cor list NWD
member NWD
dial-peer cor list Int
member Int
dial-peer cor list UAN
member UAN
dial-peer cor list Toll
member Toll
dial-peer cor list Local-BR
member Local-BR
dial-peer cor list Level1
member internal
dial-peer cor list Master
member Mobile
member Local
member NWD
member Int
member UAN
member Toll
member internal
dial-peer voice 333 voip
service aa
destination-pattern 333
session target ipv4:192.168.1.250
incoming called-number 333
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 382 pots
description *** Incoming from PSTN to (Auto-Attendant) ***
service aa
incoming called-number 382
direct-inward-dial
dial-peer voice 413 pots
trunkgroup MOB
corlist outgoing Mobile
destination-pattern 8[0][3]T
dial-peer voice 610 pots
trunkgroup FXO
corlist outgoing Local
destination-pattern 9[2-5]T
dial-peer voice 611 pots
trunkgroup FXO
corlist outgoing NWD
destination-pattern 9[0][2,3-9]T
dial-peer voice 612 pots
trunkgroup FXO
corlist outgoing UAN
destination-pattern 9[1,9]T
dial-peer voice 613 pots
trunkgroup FXO
destination-pattern 9[1]T
dial-peer voice 614 pots
trunkgroup FXO
corlist outgoing Toll
destination-pattern 9[0][8]T
dial-peer voice 615 pots
trunkgroup FXO
corlist outgoing Int
destination-pattern 9[0][0]T
dial-peer voice 1000 voip
description incoming calls from 02138899
translation-profile incoming sip_incoming
session protocol sipv2
session target sip-server
incoming called-number 3889900.
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2000 voip
translation-profile outgoing remove_prefix
destination-pattern 7.T
session target ipv4:43.242.100.1
no voice-class sip early-offer forced
dtmf-relay sip-notify rtp-nte
codec g711ulaw
no vad
dial-peer voice 701 voip
description SIP for new Building
destination-pattern 2..
session target ipv4:172.16.1.1
incoming called-number 1..
codec g711ulaw
telephony-service
no auto-reg-ephone
max-ephones 110
max-dn 288
ip source-address 192.168.1.250 port 2000
system message NEXTEK
load 7911 SCCP11.8-5-4S.loads
load 7945 SCCP45.8-5-4S.loads
time-zone 37
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern .T
call-forward pattern 1..
web admin system name admin password Basil003
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 13
button-layout 7931 1
ephone-dn 1 octo-line
number 200
label Operator
description Operator
name Operator
corlist incoming Master
ephone-dn 3 dual-line
number 105
label 105
description Arsalna
name Arsalna
ephone 1
mac-address 001B.D4C6.5E8F
type 7911
button 1:1
ephone 3
mac-address 5017.FF97.8A2E
type 7945
button 1:3
line con 0
line aux 0
line vty 0 4
password <removed>
login
transport input all
scheduler allocate 20000 1000
end
Please advise what i am doing wrong or missing.
akhundbilal
5 Replies 5
Thanks for taking time and sharing troubleshooting steps, unfortunately this did not helped.
akhundbilal
UP
akhundbilal
please use this firmware it should bootup normal.
cmterm-7945_7965-sccp9-4-2SR2-.zip
akhundbilal
file is attached
