7960 Stuck... Protocol Application Invalid*
Michael Durham
Level 4
Level 4
I have Cisco 7960G that is stuck with Protocol Application Invalid* on the display.
I bought the phone off of ebay and it was set up to use SIP.  So I upgraded it to SCCP and it worked jsut fine with CME.
I took the system down for a few weeks and when I plugged it back it, it now is stuck in this mode.  The phone does get an IP address and I can ping that address However, when I try to get to the phone in a browser, it does not reach the phone.
I can do factory reset but it does not help.
Opetion 150 is set correctly as other phones work jsut fine.
Any suggestions???
11 Replies 11
yahsiel2004
Level 7
Level 7
Did you save the right SCCP firmware on the CME router before you turned it off? Check the tftp-server config.
Yosh
HTH Regards, Yosh
I am very new to Cisco VoIP.
After I shut down the CME router (when everything was working)  I cleared the nvram and started over. The router and CME are the same but the config file is fresh. Can you point me as to where/what to check?
Michael,
This is part of a software bug
You need to put the phone on the data vlan with access
to option 150 on that scope.
Once the phone loads there you should be able to move it
back to a normal voip port
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008055c1fe.shtml
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Here are my settings:
SWITCH
interface FastEthernet0/2
description YELLOW - Phone
switchport access vlan 115
switchport mode access
switchport nonegotiate
switchport voice vlan 115
switchport port-security violation protect
switchport port-security mac-address sticky
spanning-tree portfast
interface Vlan115
ip address 10.115.0.2 255.255.255.0
ip helper-address 172.16.2.2
DHCP ROUTER
ip dhcp pool Voice
   network 10.115.0.0 255.255.255.0
   default-router 10.115.0.1
   option 150 ip 10.115.0.1
   dns-server 4.2.2.2
CME ROUTER
CME_Router#sh eph
ephone-1[0] Mac:0013.191F.4980 TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:0
IP:172.16.1.14 * 49818 Unknown 0  keepalive 0 max_line 0 available_line 0
button 1: cw:1 ccw:(0 0)
  dn 1  number 5001 CH1   DOWN         CH2   DOWN
Preferred Codec: g711ulaw
Lpcor Type: none
STILL NOT WORKING!!!
yahsiel2004
Level 7
Level 7
Take off "switchport voice vlan 115" from int fa0/2
Yosh
HTH Regards, Yosh
CME_Router#sh telephony-service all
CONFIG (Version=8.6)
Version 8.6
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 10.115.0.1 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
no auto-reg-ephone
max-ephones 5
max-dn 10
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US   (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US    (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
web admin system name Admin
web admin customer name Customer
edit DN through Web:  disabled.
edit TIME through web:  disabled.
background save interval 10 minutes
Log (table parameters):
     max-size: 150
     retain-timer: 15
create cnf-files version-stamp 7960 Jan 04 2013 19:46:31
transfer-system full-consult
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
ephone-dn 1 dual-line
number 5001
preference 0 secondary 9
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 2 dual-line
number 5002
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
ephone-dn 3 dual-line
number 5003
huntstop
no huntstop channel
call-waiting beep
no cti notify
no cti watch
Number of Configured ephones 2 (Registered 1)
ephone 1
Device Security Mode: Non-Secure
mac-address 0013.191F.4980
type 7960
button  1:1
actual keepalive 30 auxiliary 30
multicast-moh
max-calls-per-button 8
busy-trigger-per-button 0
Always send media packets to this router: No
Preferred codec: g711ulaw
conference drop-mode never
conference add-mode all
conference admin: No
privacy: Yes
privacy button: No
user-locale US
network-locale US
lpcor type:
lpcor (incoming):        (outgoing):
ephone 2
mac-address 0017.E032.E994
type 7940
button  1:2
multicast-moh
privacy: Yes
privacy button: No
user-locale US
network-locale US
lpcor type:
voice-port 50/0/1
station-id number 5001
voice-port 50/0/2
station-id number 5002
voice-port 50/0/3
station-id number 5003
dial-peer voice 20006 pots
destination-pattern 5001$
huntstop
progress_ind setup enable 3
port 50/0/1
dial-peer voice 20007 pots
destination-pattern 5002$
huntstop
port 50/0/2
dial-peer voice 20008 pots
destination-pattern 5003$
huntstop
port 50/0/3
tftp-server system:/its/united_states/7960-tones.xml alias United_States/7960-tones.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/7960-font.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/7920-font.xml
tftp-server system:/its/united_states/7960-dictionary.xml alias English_United_States/7960-dictionary.xml
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/7960-kate.xml
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/7920-kate.xml
tftp-server system:/its/united_states/SCCP-dictionary.xml alias English_United_States/SCCP-dictionary.xml
tftp-server system:/its/SEPDEFAULT.cnf alias SEPDefault.cnf
tftp-server system:/its/vrf1/XMLDefault.cnf.xml alias XMLDefault.cnf.xml
tftp-server system:/its/vrf1/ATADefault.cnf.xml alias ATADefault.cnf.xml
tftp-server system:/its/vrf1/XMLDefault7940.cnf.xml alias SEP0017E032E994.cnf.xml
tftp-server system:/its/vrf1/XMLDefault7960.cnf.xml alias SEP0013191F4980.cnf.xml
PHONE DISPLAY
TOP: Universal Application Loader
MIDDLE: Cisco logo Copywirght 2000-2008
BOTTOM: Protocol Application Invalid
Is this everything you asked for?
yahsiel2004
Level 7
Level 7
What is displaying on the phone? Can you post your "tftp-server" and "telephony service" config?
Yosh
HTH Regards, Yosh
This is your config
Make the following changes to see if we can fix
the phone.
shut
no switchport voice vlan 115
no switchport port-security violation protect
no switchport port-security mac-address sticky
no shut
Alex.
I'll get that info for you tomorrow, I have a date tonight.
DID NOT FIX THE PROBLEM
samsegura
If you have a "BRICKED" phone or "TFTP Timeout" or "Protocol Application Invalid"
Scenario:
Cisco router or Cisco switch unavailable.  Call Manager not available.
TO REBOOT PHONE:
 "*" and "6" and "Settings"
TO RESET TO FACTORY DEFAULT:
Unplug the power cable from the phone, and then plug in the cable again.
Immediately press and hold # and while the
  Headset, Mute, and Speaker buttons begin to flash in sequence, release #.
Press 123456789*0# within 60 seconds after the
  Headset, Mute, and Speaker buttons begin to flash.
When asked, select 2 to avoid saving previous configuration
PROCEDURE:
In isolated test network (configure IPs as needed)
Router IP: 192.168.0.1
Turn off DHCP on router
Put static IP on the SIP server: 192.168.0.112
Put static IP on desktop running TFTPd : 192.168.0.14
  TFTP directory, for firmware and configuration files: C:\UPDATES\TFTPDIR
Copy the per-configured tftpd32.ini to location where running tftpd.exe
  tftpd32.ini is used for both 64-bit and 32-bit
If not using per-configured tftpd32.ini:
Enable DHCP
Set up DHCP
IP Pool start address: 192.168.0.100
Size of pool: 10
Lease (minutes): 2880
Boot file: <blank>
DHCP Options
Def router (Opt 3): 192.168.0.1
Mask (Opt 1): 255.255.255.0
DNS Server (Opt 6): 192.168.0.1
WINS Server (Opt 44): 192.168.0.1
NTP Server (Opt 42):
SIP server (Opt 120): 192.168.0.112
Domain Name (15): <blank>
Additional Option: 150 | a 192.168.0.14
    Option 150 (used to identify TFTP server)
    a 192.168.0.14  (a stands for address, x for hexadecimal)
Check ON:
ping address before assignation,
Persistent leases,
Bind DHCP to this address: 192.168.0.14
Close and restart TFTPD64
Reset phone to factory default - phone will find TFTP server and configure
TFTP32.INI
[DHCP]
IP_Pool=192.168.0.100
PoolSize=10
BootFile=
DNS=192.168.0.1
DNS2=
WINS=192.168.0.1
Mask=255.255.255.0
Gateway=192.168.0.1
Option42=
Option120=192.168.0.112
DomainName=
Lease (minutes)=2880
AddOptionNumber1=150
AddOptionValue1=a 192.168.0.14
AddOptionNumber2=0
AddOptionValue2=
AddOptionNumber3=0
AddOptionValue3=
AddOptionNumber4=0
AddOptionValue4=
AddOptionNumber5=0
AddOptionValue5=
AddOptionNumber6=0
AddOptionValue6=
AddOptionNumber7=0
AddOptionValue7=
AddOptionNumber8=0
AddOptionValue8=
AddOptionNumber9=0
AddOptionValue9=
AddOptionNumber10=0
AddOptionValue10=
Lease_NumLeases=0
[TFTPD32]
BaseDirectory=C:\UPDATES\TFTPDIR
TftpPort=69
Hide=0
WinSize=0
Negociate=1
PXECompatibility=0
DirText=0
ShowProgressBar=1
Timeout=3
MaxRetransmit=6
SecurityLevel=0
UnixStrings=1
Beep=0
VirtualRoot=0
MD5=0
LocalIP=192.168.0.14
Services=5
TftpLogFile=
SaveSyslogFile=
PipeSyslogMsg=0
LowestUDPPort=0
HighestUDPPort=0
MulticastPort=0
MulticastAddress=
PersistantLeases=1
UnicastBOOTP=0
DHCP Ping=1
DHCP Double Answer=0
DHCP LocalIP=
Max Simultaneous Transfers=100
UseEventLog=0
Console Password=tftpd32
Support for port Option=0
Keep transfer Gui=5
Ignore ack for last TFTP packet=0
Enable IPv6=1
