12-11-2013 08:46 PM - edited 03-16-2019 08:49 PM
CUCM System version: 8.6.2.20000-2
Phone is a 7960
When the user tries to setup call forwarding on the device for after hours coverage, there is a voice prompt saying "The call cannot be completed as dialed" before he is finished entering the number to be forwarded to.
When I try to go into the DN configuration page in CUCM and set the number to forward to the desired number, it sets the forward without any error message in CUCM, but when I call the extension from my cell phone, it never gives a ringback, so I don't think it is actually trying to do anything.
I have deleted the phone from the system, let it boot back up and pull an "Auto 2xxx" number, then reconfigured the original DN.
There are no other devices with this DN on it.
I configured that DN on 7925 for him to carry around overnight tonight, and I will have to fix it before the weekend.
I am not very experienced with CUCM/ Cisco VOIP but am now "the man" due to terminations and resignations lately.
What would cause this??
Message was edited by: James Gladwell
Solved! Go to Solution.
12-12-2013 05:47 AM
Hi James,
Just to add a note to the good tips from Nishant here (+5 )
In CUCM there are "dial restriction" levels that you can use to allow or
restrict where users can call based on their CSS (calling search space)
This restriction level CSS can also be applied to the Call Forward capabilities
as shown below & is likely where your problem lies.
This requirement for different levels of "restriction" for Call Forward All
can be controlled by using the Call Forward CSS(calling search space)
as detailed below
# Call Forward and Call Pickup Settings | |
# Calling Search Space Activation Policy | # Three possible values exist for this option: ###•With Activating Device/Line CSS #If you select the With Configured CSS option, the Forward All Calling Search Space that is explicitly configured in the Directory Number Configuration window controls the forward all activation and call forwarding. If the Forward All Calling Search Space is set to None, no CSS gets configured for Forward All. A forward all activation attempt to any directory number with a partition will fail. No change in the Forward All Calling Search Space and Secondary Calling Search Space for Forward All occurs during the forward all activation. #If you prefer to utilize the combination of the Directory Number Calling Search Space and Device Calling Search Space without explicitly configuring a Forward All Calling Search Space, select With Activating Device/Line CSS for the Calling Search Space Activation Policy. With this option, when Forward All is activated from the phone, the Forward All Calling Search Space and Secondary Calling Search Space for Forward All automatically gets populated with the Directory Number Calling Search Space and Device Calling Search Space for the activating device. #With this configuration (Calling Search Space Activation Policy set to With Activating Device/Line), if the Forward All Calling Search Space is set to None, when forward all is activated through the phone, the combination of Directory Number Calling Search Space and activating Device Calling Search Space gets used to verify the forward all attempt. #If you configure the Calling Search Space Activation Policy to Use System Default, then the CFA CSS Activation Policy cluster-wide service parameter determines which Forward All Calling Search space will be used. If the CFA CSS Activation Policy service parameter gets set to With Configured CSS, then Forward All Calling Search Space and Secondary Calling Search Space for Forward All will be used for Call Forwarding. If CFA CSS Activation Policy service parameter gets set to With Activating Device/Line CSS, then Forward All Calling Search Space and Secondary Calling Search Space for Forward All will be automatically populated with the Directory Number Calling Search Space and Device Calling Search Space for the activating device. |
# | # CFA CSS Activation Policy Service Parameter #Ensure the CFA CSS Activation Policy service parameter that displays in the Clusterwide Parameters (Feature - Forward) section of the Service Parameter Configuration window is set correctly for call forward all to work as intended. The parameter includes two possible values: #•With Configured CSS (default) #•With Activating Device/Line CSS #When the Calling Search Space Activation Policy is set to Use System Default, the value of the CFA CSS Activation Policy service parameter gets used to determine the Call Forward All CSS. #When the option With Configured CSS is selected, the primary and secondary CFA Calling Search Space get used. When the option With Activating Device/Line CSS is selected, the primary and secondary CFA Calling Search Space get updated with primary line Calling Search Space and activating Device Calling Search Space. #By default, the value of the CFA CSS Activation Policy service parameter is set to With Configured CSS. #See Service Parameters Configuration for information on accessing and configuring service parameters. #Roaming #When a device is roaming in the same device mobility group, Cisco Unified Communications Manager uses the Device Mobility CSS to reach the local gateway. If a user sets Call Forward All at the phone, the CFA CSS is set to None, and the CFA CSS Activation Policy is set to With Activating Device/Line CSS, then: #•The Device CSS and Line CSS get used as the CFA CSS when the device is in its home location. #•If the device is roaming within the same device mobility group, the Device Mobility CSS from the Roaming Device Pool and the Line CSS get used as the CFA CSS. #•If the device is roaming within a different device mobility group, the Device CSS and Line CSS get used as the CFA CSS. |
# Forward All | # The settings in this row of fields specify the forwarding treatment for calls to this directory number if the directory number is set to forward all calls. The Calling Search Space field gets used to validate the Forward All destination that is entered when the user activates Call Forward All from the phone. This field also gets used to redirect the call to the Call Forward All destination. #Specify the following values: #•Voice Mail—Check this check box to use settings in the Voice Mail Profile Configuration window. #Note When this check box is checked, Cisco Unified Communications Manager ignores the settings in the Destination box and Calling Search Space. #•Destination—This setting indicates the directory number to which all calls are forwarded. Use any dialable phone number, including an outside destination. #•Calling Search Space—This setting applies to all devices that are using this directory number. |
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b03dn.html
And beautifully explained by one of the very BEST, Hailey from CNC here;
Cheers!
Rob
"When it comes to luck you make your own "
- Springsteen
12-11-2013 09:14 PM
Hi James,
Please check as below:-
1). Call that number directly before setting it as forward number and check if you are able to dial it or not.
2). If you are not able to dial then check the partition and CSS, whether that phone has got the access to call that number.
Nishant Savalia
12-12-2013 05:47 AM
Hi James,
as detailed below
Cheers!
Rob
- Springsteen
12-12-2013 10:30 AM
Thanks guys.
I had to give it the correct CSS under Call Forward and Call Pickup Settings for "Forward All" and it now works.
