Walkthrough Wednesdays
876
Sean Ross
Beginner
7961 ethernet disconnect with docking stations
Hello all - so strange issue here which didn't start after upgrading to CUCM 8.6.  Everything in the environment works just fine except for users who daisy chain(phone to wallport and docking station into phone) into docking stations with 7961's.   Whenever they shut down their laptop the phone errors out and displays "Ethernet disconnect".
The user states that the phone doesn't regain connectivity until they turn their laptop back on however I've tested with a docking station and a 7961 daisy chained and after powering down the laptop the phone does go into a Ethernet disconnect but after around 5-10secs it will re-register to CUCM with no issues.
so the question is what does the laptop powering down have to do with the phone not being able contact CUCM? Because the phone is plugged into the wallport and the laptop is plugged into the phone.  I assume that the Ethernet disconnect is from the port that the laptop is plugged into but again the phone shouldnt lose connection .   I guess upgrade firmware?
Below is the version info of the phone and some status logs
App Load ID
jar41sccp.9-3-1ES8.sbn
Boot Load ID
7961G_64-02070631Amd64megRel.bin
Version
9.3(1SR1.1S)
Expansion Module 1
Expansion Module 2
Hardware Revision
1.0
4:27:16p Trust List Updated
4:27:16p SEP001F6C81331D.cnf.xml.sgn(HTTP)
4:50:15p Trust List Updated
4:50:15p SEP001F6C81331D.cnf.xml.sgn(HTTP)
5:02:47p Ethernet Disconnected
5:02:53p Trust List Updated
5:02:53p SEP001F6C81331D.cnf.xml.sgn(HTTP)
5:07:06p Ethernet Disconnected
5:07:11p Trust List Updated
5:07:11p SEP001F6C81331D.cnf.xml.sgn(HTTP)
7:17:49p 25: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=Initialized
7:09:47p 25: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=Initialized
2:16:21p 23: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=Reset-Restart
2:18:10p 6: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) File Not Found
2:18:10p 22: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=Reset-Reset
2:18:27p 23: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=Reset-Restart
2:19:54p 14: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=UCM-closed-TCP
2:28:41p 14: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=UCM-closed-TCP
3:59:30p 14: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=UCM-closed-TCP
3:59:52p 14: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=UCM-closed-TCP
4:17:25p 14: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=UCM-closed-TCP
4:23:41p 14: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=UCM-closed-TCP
4:26:45p 14: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=UCM-closed-TCP
4:27:21p 14: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=UCM-closed-TCP
4:50:23p 22: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=Reset-Reset
5:02:57p 14: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=UCM-closed-TCP
5:07:16p 14: Name=SEP001F6C81331D Load= 9.3(1SR1.1S) Last=UCM-closed-TCP
0 REPLIES 0
Content for Community-Ad
Spotlight Awards 2021
