10-28-2010 08:30 PM - edited 03-16-2019 01:37 AM
I have three Cisco 7962 IP Phones. Is it possible to determine if the phone in use (on-going call) via SNMP MIB query or SIP message? I want to integrate the phones with an in-house monitoring system. I need a method that can be executed from remote, like sending a request or retrieving information via SNMP, SIP, etc. The method should be communicated directly to the phone.
Any help is greatly appreaciated.
sho
10-28-2010 11:23 PM
You probably want to be looking at Presence to monitor phone status.
Using just CUCM you can configure Busy Lamp Field (BLF) monitoring which allows you to see from a phone handset whether a phone is off-hook using a speed dial or within Corporate Directory.
If you want to integrate Presence into applications you will need to deploy a CUPS server.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps6837/data_sheet_c78-586995.html
The Cisco Developer Network has details about Presence APIs
10-29-2010 01:38 AM
Thanks for your response.
Instead of CUPS, can I use Jabberd or any Open Source Presence servers? Has anyone tried this?
