nosferatus96
What is this Dial-peer 1 for ? Shut down the dial-peer 1 and check the calls.
dial-peer voice 1 voip
description CISCO
destination-pattern 1000...
session protocol sipv2
session target ipv4:*classified*
voice-class codec 1
dtmf-relay rtp-nte
Response Signature
Thanks for the fast reply,
Originally I have 10 different dial-peers, all having that same issues, I presume without the dial-peers that it would work properly, but I need it to work with them, could there be something wrong with it? the destination-pattern is 1000... but it's like the router doesn't recognise the wildcard periods and only uses the first 4 numbers. have you experienced that on the ISR 4331?
Could you please post your complete configuration
Response Signature
