7965 SIP FAILED TO REGISTRATION
Armel
HI , any can help here , everything , I am configure this sccp 7965 as SIP phone , its already failed to registrar ,,here is my configure need help
BR2 :FAILED TO REGISTRATION 7965 AS IP
Device ID: SEP002290BA362F
Entry address(es):
  IP address: 10.1.130.10
Platform: Cisco IP Phone 7965,  Capabilities: Host Two-port Mac Relay
Interface: GigabitEthernet0/1/0,  Port ID (outgoing port): Port 1
Holdtime : 134 sec
Second Port Status: Down
Version :
SCCP45.9-3-1SR1-1S
Configue
User Access Verification
Password:
BR2>en
Password:
BR2#show run
Building configuration...
Current configuration : 5139 bytes
! Last configuration change at 21:53:17 UTC Fri Oct 20 2017
! NVRAM config last updated at 21:54:05 UTC Fri Oct 20 2017
version 15.2
hostname BR2
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.152-4.M3.bin
boot-end-marker
card type e1 0 0
enable password cisco123
no aaa new-model
network-clock-participate wic 0
ip cef
ip dhcp excluded-address 10.1.130.1 10.1.130.9
ip dhcp excluded-address 10.1.130.21 10.1.130.254
ip dhcp excluded-address 10.1.30.1 10.1.30.9
ip dhcp excluded-address 10.1.30.21 10.1.30.254
ip dhcp pool Data
 network 10.1.30.0 255.255.255.0
 default-router 10.1.30.1
ip dhcp pool Voice
 network 10.1.130.0 255.255.255.0
 default-router 10.1.130.1
 option 150 ip 10.1.130.1
no ip domain lookup
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface Vlan130
  bind media source-interface Vlan130
  registrar server
voice register global
 mode cme
 source-address 10.1.130.1 port 5060
 max-dn 2
 max-pool 2
 load 7965 SIP45.9-3-1SR1-1S
 timezone 22
 date-format D/M/Y
 url authentication http://10.1.130.1/CCMCIP/authenticate.asp
 tftp-path flash:
 create profile sync 002044056103039A
 ntp-server 10.1.10.1 mode directedbroadcast
voice register dn  1
 number 4001
 name 2288224001
voice register pool  1
 id mac 0022.90BA.362F
 type 7965
 number 1 dn 1
 dtmf-relay rtp-nte
 description 2288224001
 no vad
license udi pid CISCO2921/K9 sn FTX1717ALU3
hw-module pvdm 0/0
hw-module sm 1
vtp mode transparent
redundancy
controller E1 0/0/0
 pri-group timeslots 1-12,16
vlan 30
vlan 130
 name BR2-Voice
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 service-module enable
interface GigabitEthernet0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 no cdp enable
interface Serial0/2/0
 no ip address
 encapsulation frame-relay IETF
 frame-relay lmi-type ansi
interface Serial0/2/0.102 point-to-point
 ip address 10.13.1.2 255.255.255.0
 mpls ip
 frame-relay interface-dlci 102
interface GigabitEthernet0/1/0
 description BR2 Phone 1
 switchport access vlan 30
 switchport voice vlan 130
 no ip address
 spanning-tree portfast
interface GigabitEthernet0/1/1
 no ip address
interface GigabitEthernet0/1/2
 description Trunk for L2TPv3 - DO NOT MODIFY
 switchport mode trunk
 no ip address
interface GigabitEthernet0/1/3
 no ip address
interface SM1/0
 no ip address
 shutdown
 !Application: CUE Running on SM
interface SM1/1
 description Internal switch interface connected to Service Module
 no ip address
interface Vlan1
 no ip address
interface Vlan30
 ip address 10.1.30.1 255.255.255.0
interface Vlan130
 ip address 10.1.130.1 255.255.255.0
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.1.130.1
router eigrp 10
 network 10.0.0.0
ip forward-protocol nd
ip http server
no ip http secure-server
cdp timer 5
tftp-server flash:SIP/apps45.9-3-1ES8.sbn alias apps45.9-3-1ES8.sbn
tftp-server flash:SIP/cnu45.9-3-1ES8.sbn alias cnu45.9-3-1ES8.sbn
tftp-server flash:SIP/cvm45sip.9-3-1ES8.sbn alias cvm45sip.9-3-1ES8.sbn
tftp-server flash:SIP/dsp45.9-3-1ES8.sbn alias dsp45.9-3-1ES8.sbn
tftp-server flash:SIP/jar45sip.9-3-1ES8.sbn alias jar45sip.9-3-1ES8.sbn
tftp-server flash:SIP/SIP45.9-3-1SR1-1S.loads alias SIP45.9-3-1SR1-1S.loads
tftp-server flash:SIP/term45.default.loads alias term45.default.loads
tftp-server flash:SIP/term65.default.loads alias term65.default.loads
control-plane
voice-port 0/0/0:15
mgcp profile default
gatekeeper
 shutdown
telephony-service
 authentication credential grade grade
 service phone webAccess 0
 max-conferences 8 gain -6
 transfer-system full-consult
line con 0
 location 360CLB01-LAB-WKB01, SJ
 exec-timeout 0 0
 logging synchronous
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 no exec
 transport input all
 transport output all
 stopbits 1
line vty 0 4
 exec-timeout 0 0
 password cisco123
 login
 transport input all
line vty 5 15
 exec-timeout 0 0
 password cisco123
 login
 transport input all
scheduler allocate 20000 1000
ntp server 10.1.10.1
end
BR2#
Gregory Brunn
Your phone is reporting via CDP a SCCP firmware load but I see that you are trying to use sip... when the phone pulls it options 150 what do you see on the phone are you getting firmware update errors? What is in the status messages of the phone say? can you post the out put of debug tftp event?
