7971 SIP Phone Hung on "Registering"
CChambleeJr1961
Running CME on 3825 router, with several SCCP VoIP phones up and running fine.  Also has Unity Express VM, working fine.  Now I'm trying to add a SIP phone.  The phone has aquired an IP address from DHCP, and has TFTP server location and CM IP address.  The issue is, the phone is stuck at the "Registering" point.  Display shows the correct DN, just won't complete registration.  Running config, SHOW VOICE REGISTER STATISTICS and DEBUG CCSIP MESSAGES debugs below.
CME-172-16-1-1#sh run
Building configuration...
Current configuration : 10263 bytes
! Last configuration change at 15:22:38 central Tue Mar 1 2016 by Chuck
version 15.1
hostname CME-172-16-1-1
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/2
enable password CCJr4471425Enable
no aaa new-model
clock timezone central -6 0
clock summer-time central recurring
no network-clock-participate slot 1
no network-clock-participate slot 2
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp pool VOICE
network 172.16.100.0 255.255.255.0
default-router 172.16.100.254
option 150 ip 172.16.1.1
no ip domain lookup
no ipv6 cef
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
dspfarm
voice-card 2
dspfarm
voice service voip
no ip address trusted authenticate
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
registrar server expires max 3600 min 120
voice register global
mode cme
source-address 172.16.1.1 port 5060
max-dn 20
max-pool 20
load 7941 SIP41.9-4-2SR1-1S
timezone 8
voicemail 2000
tftp-path flash:
create profile sync 0072444459544757
voice register dn 2
number 5101
allow watch
name Office
label 5101
mwi
voice register pool 2
id mac 0016.C852.7E1C
type 7941
number 1 dn 2
presence call-list
dtmf-relay rtp-nte
username cisco password cisco
call-forward b2bua busy 2000
codec g711ulaw
no vad
license udi pid CISCO3825 sn FTX1224A105
username cisco privilege 15 password 0 cisco
username Chuck privilege 0 password 0 CCJr4471425
redundancy
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
media-type sfp
negotiation auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 172.16.1.1 255.255.255.0
interface GigabitEthernet0/0.100
encapsulation dot1Q 100
ip address 172.16.100.1 255.255.255.0
interface GigabitEthernet0/0.101
encapsulation dot1Q 101
ip address 192.168.1.2 255.255.255.0
interface Service-Engine0/0
ip unnumbered GigabitEthernet0/0.1
service-module ip address 172.16.1.2 255.255.255.0
service-module ip default-gateway 172.16.1.1
interface GigabitEthernet0/1
description SIP trunk to CME-2
ip address 10.0.185.70 255.255.255.0
duplex full
speed 100
media-type rj45
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/GUI
ip route 172.16.1.2 255.255.255.255 Service-Engine0/0
ip route 172.16.2.0 255.255.255.0 172.16.1.254
tftp-server flash:term06.default.loads
tftp-server flash:term41.default.loads
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:Desktops/320x212x12/CampusNight.png
tftp-server flash:Desktops/320x212x12/CiscoFountain.png
tftp-server flash:Desktops/320x212x12/MorroRock.png
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/TN-MorroRock.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/Fountain.png
tftp-server flash:Desktops/320x212x12/CiscoLogo.png
tftp-server flash:Desktops/320x212x12/TN-CiscoLogo.png
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:term61.default.loads
tftp-server flash:term75.default.loads
tftp-server flash:P00307020400.bin
tftp-server flash:P00307020400.loads
tftp-server flash:P00307020400.sb2
tftp-server flash:P00307020400.sbn
tftp-server flash:P0030801SR02.sbn
tftp-server flash:P0030801SR02.loads
tftp-server flash:P0030801SR02.sb2
tftp-server flash:P0030801SR02.bin
tftp-server flash:P00308010200.sbn
tftp-server flash:P00308010200.loads
tftp-server flash:P00308010200.sb2
tftp-server flash:P00308010200.bin
tftp-server flash:P00308000400.bin
tftp-server flash:P00308000400.loads
tftp-server flash:P00308000400.sb2
tftp-server flash:P00308000400.sbn
tftp-server flash:term31.default.loads
tftp-server flash:SCCP31.9-4-2SR1-1S.loads
tftp-server flash:jar31sccp.9-4-2ES9.sbn
tftp-server flash:dsp31.9-4-2ES9.sbn
tftp-server flash:cvm31sccp.9-4-2ES9.sbn
tftp-server flash:cnu31.9-4-2ES9.sbn
tftp-server flash:apps31.9-4-2ES9.sbn
tftp-server flash:SIP41.9-4-2SR1-1S.loads
tftp-server flash:jar41sip.9-4-2ES9.sbn
tftp-server flash:dsp41.9-4-2ES9.sbn
tftp-server flash:cvm41sip.9-4-2ES9.sbn
tftp-server flash:cnu41.9-4-2ES9.sbn
tftp-server flash:apps41.9-4-2ES9.sbn
control-plane
voice-port 1/0/0
connection plar 5001
caller-id enable
voice-port 1/0/1
connection plar 5002
caller-id enable
voice-port 1/0/2
connection plar 5003
caller-id enable
voice-port 1/0/3
voice-port 2/0/0
ring cadence pattern01
station-id name Charles
station-id number 5011
caller-id enable
voice-port 2/0/1
mgcp profile default
sccp local GigabitEthernet0/0.1
sccp ccm 172.16.1.1 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register CME-XCODER
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 6
associate application SCCP
dial-peer voice 1 voip
destination-pattern 2...
session protocol sipv2
session target ipv4:172.16.1.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 11 pots
destination-pattern 9[2-9].........
port 1/0/3
prefix 99,
dial-peer voice 21 pots
destination-pattern 5011
port 2/0/0
dial-peer voice 31 voip
description Outbound SIP to CME-2 - Local
destination-pattern 4...
session target ipv4:10.0.185.71
dtmf-relay rtp-nte
dial-peer voice 32 voip
description Incoming from CME-2
destination-pattern 5...
dtmf-relay rtp-nte
dial-peer voice 33 voip
description Outbound SIP to Avaya Lab
destination-pattern 300....
session target ipv4:10.0.185.235
session transport tcp
dtmf-relay rtp-nte
dial-peer voice 34 voip
description Incoming SIP from Avaya
dtmf-relay rtp-nte
sip-ua
telephony-service
sdspfarm units 2
sdspfarm transcode sessions 6
sdspfarm tag 1 CME-XCODER
max-ephones 30
max-dn 45
ip source-address 172.16.1.1 port 2000
auto assign 1 to 10 type 7912
auto assign 1 to 10 type 7941
auto assign 1 to 10 type 7940
auto assign 1 to 10 type 7960
auto assign 1 to 10 type 7961
auto assign 1 to 10 type 7965
auto assign 1 to 10 type 7945
auto assign 1 to 10 type 7942
auto assign 1 to 10 type 7962
auto assign 1 to 10 type 7970
auto assign 1 to 10 type 7971
auto assign 1 to 10 type 7975
system message B5298 Voice Lab 1
cnf-file location flash:
load 7912 term06.default.loads
load 7960-7940 P00308000400
load 7941 term41.default.loads
load 7942 term42.default.loads
load 7945 term45.default.loads
load 7961 term61.default.loads
load 7962 term62.default.loads
load 7965 term65.default.loads
load 7970 term70.default.loads
load 7971 term71.default.loads
load 7975 term75.default.loads
time-zone 8
voicemail 2000
max-conferences 4 gain -6
web admin system name cisco password cisco
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
number 5001
label Chuck
name Chuck
preference 1 secondary 2
call-forward busy 2000
call-forward noan 2000 timeout 12
ephone-dn 2 dual-line
number 5002
label Greg
name Greg
ephone-dn 3 dual-line
number 5003
label Sam
name Sam
ephone-dn 4 dual-line
number 1004
ephone-dn 5 dual-line
number 1005
ephone-dn 6 dual-line
number 1006
ephone-dn 7 dual-line
number 1007
ephone-dn 8 dual-line
number 1008
ephone-dn 9 dual-line
number 1009
ephone-dn 10 dual-line
number 1010
ephone-dn 21
number 8000....
mwi on
ephone-dn 22
number 8001....
mwi off
ephone 1
device-security-mode none
mac-address 0012.0138.3FD2
type 7960
button 1:2
ephone 2
mac-address 0016.C815.61DD
type 7960
button 1:1
ephone 3
mac-address 0016.468A.DD37
type 7960
button 1:3
ephone 4
mac-address 001B.D423.FB79
max-calls-per-button 2
type 7931
button 1:4 2:1 3:2 4:3
ephone 5
mac-address 0017.5A5B.2A74
type 7960
button 1:5
ephone 6
mac-address 000C.8533.CD16
type 7960
button 1:6
ephone 7
mac-address 001C.5857.81B7
type 7960
button 1:7
line con 0
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
exec-timeout 60 0
login local
transport input all
line vty 5 15
exec-timeout 120 0
login
transport input all
scheduler allocate 20000 1000
ntp server 172.16.1.4
ntp server 172.16.1.9
end
CME-172-16-1-1#
And here's a show voice register statistics:
CME-172-16-1-1#sh voice register stat
Global statistics
Active registrations : 0
Total SIP phones registered: 0
Total Registration Statistics
Registration requests : 383
Registration success : 10
Registration failed : 373
unRegister requests : 10
unRegister success : 10
unRegister failed : 0
Attempts to register
after last unregister : 313
Last register request time : *15:25:09.503 central Mon Feb 29 2016
Last unregister request time : *13:51:31.455 central Mon Feb 29 2016
Register success time : *13:31:31.455 central Mon Feb 29 2016
Unregister success time : *13:51:31.456 central Mon Feb 29 2016
Register pool 3 statistics
Registration requests : 5
Registration success : 5
Registration failed : 0
unRegister requests : 5
unRegister success : 5
after last unregister : 0
Last register request time : *13:30:42.295 central Mon Feb 29 2016
Last unregister request time : *13:50:42.295 central Mon Feb 29 2016
Register success time : *13:30:42.295 central Mon Feb 29 2016
Unregister success time : *13:50:42.296 central Mon Feb 29 2016
Reason for unregistered state:
No registration request since last reboot/unregister
Register pool 4 statistics
Last register request time : *13:31:31.455 central Mon Feb 29 2016
CME-172-16-1-1#
CME-172-16-1-1#
*Mar 1 20:59:09.402: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:172.16.1.1 SIP/2.0
Via: SIP/2.0/UDP 172.16.100.6:5060;branch=z9hG4bKe84ee61d
From: <sip:5101@172.16.1.1>;tag=0016c8527e1c0005fa871708-4294e487
To: <sip:5101@172.16.1.1>
Call-ID: 0016c852-7e1c0005-d6ae82ca-b9791911@172.16.100.6
Max-Forwards: 70
Date: Fri, 17 Apr 2015 08:24:38 GMT
CSeq: 104 REGISTER
User-Agent: Cisco-CP7941G/9.4.2
Contact: <sip:5101@172.16.100.6:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-0016c8527e1c>";+u.sip!devicename.ccm.cisco.com="SEP0016C8527E1C";+u.sip!model.ccm.cisco.com="115"
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-6.0.0,X-cisco-xsi-8.5.1
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:14 Name=SEP0016C8527E1C Load=SIP41.9-4-2SR1-1S Last=cm-closed-tcp"
Expires: 3600
*Mar 1 20:59:09.406: //37/47163B90804F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 01 Mar 2016 20:59:09 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 104 REGISTER
Content-Length: 0
Sent:
SIP/2.0 200 OK
To: <sip:5101@172.16.1.1>;tag=4A17214-1F63
CSeq: 104 REGISTER
Supported: X-cisco-cme-sis-1.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:5101@172.16.100.6:5060>;expires=3600;x-cisco-newreg
Expires: 3600
Content-Length: 0
*Mar 1 20:59:09.406: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:5101@172.16.100.6:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.16.100.1:5060;branch=z9hG4bK11124
To: <sip:5101@172.16.100.6>
Call-ID: 4716D7B8-DF2711E5-8050EBE3-A9F56133@172.16.100.1
CSeq: 101 NOTIFY
Max-Forwards: 70
User-Agent: Cisco-SIPGateway/IOS-12.x
Event: service-control
Subscription-State: active
Contact: <sip:5101@172.16.100.1:5060>
Content-Type: text/plain
Content-Length: 190
action=check-version
RegisterCallId={0016c852-7e1c0005-d6ae82ca-b9791911@172.16.100.6}
ConfigVersionStamp={0072444459544752}
DialplanVersionStamp={}
SoftkeyVersionStamp={0072444459544752}
*Mar 1 20:59:09.410: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.16.100.1:5060;branch=z9hG4bK12C37
Call-ID: 47177478-DF2711E5-8051EBE3-A9F56133@172.16.100.1
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: message-summary
Content-Type: application/simple-message-summary
Content-Length: 22
Messages-Waiting: no
*Mar 1 20:59:09.898: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:09.898: //37/47163B90804F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 104 REGISTER
Expires: 3600
Content-Length: 0
*Mar 1 20:59:09.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 190
*Mar 1 20:59:09.910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 22
*Mar 1 20:59:10.890: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:10.894: //37/47163B90804F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 01 Mar 2016 20:59:10 GMT
CSeq: 104 REGISTER
Expires: 3600
Content-Length: 0
*Mar 1 20:59:10.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 190
*Mar 1 20:59:10.910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 22
*Mar 1 20:59:12.890: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:12.894: //37/47163B90804F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 01 Mar 2016 20:59:12 GMT
CSeq: 104 REGISTER
Expires: 3600
Content-Length: 0
*Mar 1 20:59:12.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 190
*Mar 1 20:59:12.910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 22
*Mar 1 20:59:16.890: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:16.894: //37/47163B90804F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 01 Mar 2016 20:59:16 GMT
CSeq: 104 REGISTER
Expires: 3600
Content-Length: 0
*Mar 1 20:59:16.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 190
*Mar 1 20:59:16.910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 22
*Mar 1 20:59:20.890: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:20.894: //37/47163B90804F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 01 Mar 2016 20:59:20 GMT
CSeq: 104 REGISTER
Expires: 3600
Content-Length: 0
*Mar 1 20:59:20.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 190
*Mar 1 20:59:20.910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 22
*Mar 1 20:59:24.898: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:24.898: //37/47163B90804F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 01 Mar 2016 20:59:24 GMT
CSeq: 104 REGISTER
Expires: 3600
Content-Length: 0
*Mar 1 20:59:24.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 190
*Mar 1 20:59:24.910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 22
*Mar 1 20:59:28.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 190
*Mar 1 20:59:28.910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 22
*Mar 1 20:59:28.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:28.966: //37/47163B90804F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 01 Mar 2016 20:59:28 GMT
CSeq: 104 REGISTER
Expires: 3600
Content-Length: 0
*Mar 1 20:59:32.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 190
*Mar 1 20:59:32.910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 22
*Mar 1 20:59:32.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:32.966: //37/47163B90804F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 01 Mar 2016 20:59:32 GMT
CSeq: 104 REGISTER
Expires: 3600
Content-Length: 0
*Mar 1 20:59:36.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 190
*Mar 1 20:59:36.910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 22
*Mar 1 20:59:36.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:36.966: //37/47163B90804F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 01 Mar 2016 20:59:36 GMT
CSeq: 104 REGISTER
Expires: 3600
Content-Length: 0
*Mar 1 20:59:40.906: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 190
*Mar 1 20:59:40.910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 NOTIFY
Max-Forwards: 70
Content-Length: 22
*Mar 1 20:59:40.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:40.970: //37/47163B90804F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 01 Mar 2016 20:59:40 GMT
CSeq: 104 REGISTER
Expires: 3600
Content-Length: 0
*Mar 1 20:59:44.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:44.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 01 Mar 2016 20:59:44 GMT
CSeq: 104 REGISTER
Content-Length: 0
*Mar 1 20:59:44.966: //39/5C4840D68052/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
To: <sip:5101@172.16.1.1>;tag=4A1FCFC-1DF9
CSeq: 104 REGISTER
Content-Length: 0
*Mar 1 20:59:45.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:47.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:47.966: //40/5E1204568053/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 01 Mar 2016 20:59:47 GMT
CSeq: 104 REGISTER
Content-Length: 0
Sent:
To: <sip:5101@172.16.1.1>;tag=4A208B4-23CA
CSeq: 104 REGISTER
Content-Length: 0
*Mar 1 20:59:51.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:55.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 20:59:55.966: //41/62D6B8568054/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 01 Mar 2016 20:59:55 GMT
CSeq: 104 REGISTER
Content-Length: 0
Sent:
To: <sip:5101@172.16.1.1>;tag=4A227F4-13DA
CSeq: 104 REGISTER
Content-Length: 0
*Mar 1 20:59:59.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 21:00:03.970: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 21:00:03.970: //42/679CA53E8055/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 01 Mar 2016 21:00:03 GMT
CSeq: 104 REGISTER
Content-Length: 0
Sent:
To: <sip:5101@172.16.1.1>;tag=4A2473C-92A
CSeq: 104 REGISTER
Content-Length: 0
*Mar 1 21:00:07.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 21:00:11.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
*Mar 1 21:00:11.966: //43/6C6020568056/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 01 Mar 2016 21:00:11 GMT
CSeq: 104 REGISTER
Content-Length: 0
Sent:
To: <sip:5101@172.16.1.1>;tag=4A26678-1259
CSeq: 104 REGISTER
Content-Length: 0
*Mar 1 21:00:15.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 104 REGISTER
Content-Length: 0
Expires: 3600
Can anyone spot the problem and advise?
is the "type" set correctly for the 7971 phone?
Yes.  I have both a 7941 and a 7971, both do the same thing.  I moved the 7971 over to a second CME lab system.  I'm sure if the issue is resolved with the 7941 then the 7971 will work, as well.
