09-11-2013 02:25 PM - edited 03-16-2019 07:19 PM
I recently did an upgrade from 8.5 to 8.6 and received this warning: Missing Software Feature License
I contacted TAC and they sent to me a temporary license (CM8.6-K9-UPG=), but was not able to tell me how to permanently fix this issue.
This PN (CM8.6-K9-UPG=) has a price list of $15k, its not an affordable price for a MINOR upgrade.
There is no UCSS, but i understand that UCSS is only for major upgrade, and what im doing is a minor upgrade. Recently I did an upgrade from 8.0 to 8.6 and i didnt had this problem.
So, anyone knows how can i permanently fix this issue?
thanks
09-11-2013 05:31 PM
Is the license still installed on the server??
If so, have you tried deleting it and adding it again??
You can also try with licensing and let them know this was a minor upgrade and that a glitch removed the license and ask them to issue a new one.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
09-13-2013 05:47 AM
Which license are you asking about?
09-13-2013 08:51 PM
You can ask licensing team to provide u the the existing license files running on 8.x as suggested by Mr. Jaime.
you can delete the existing file and upload the new one.
from CLI using OS administration , issue command file delete license filename[CCMxxxxxx.lic]
regds,
aman
