8007490000- not working from STC SIP Trunk in saudi Arabia
Please find the attached traces from our gateway and STC side. STC is saying PBX problem
Can anybody from Saudi test this by dialing 8007490000 from their SIP trunk .
Tested it for you and got the same exact result, however it's working fine from FXO/ PRI lines.
*Apr 12 14:32:04.359: //528456/956488000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:8007490000@X.X.X.X:5060 SIP/2.0
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK39D023D9
Remote-Party-ID: "Jaffar AlMoosa" <sip:XXXXXXX@X.X.X.X>;party=calling;screen=yes;privacy=off
From: "User Name" <sip:XXXXXXX@X.X.X.X>;tag=A953444-DE8
To: <sip:8007490000@X.X.X.X>
Date: Sun, 12 Apr 2015 14:32:04 GMT
Call-ID: 860A521A-E05711E4-A69CF05C-2FA133A4@X.X.X.X
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2506393600-0000065536-0000003249-3473633290
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1428849124
Contact: <sip:XXXXXXX@X.X.X.X:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 68
Session-Expires:  1800
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 271
v=0
o=CiscoSystemsSIP-GW-UserAgent 9860 1174 IN IP4 X.X.X.X
s=SIP Call
c=IN IP4 X.X.X.X
t=0 0
m=audio 21954 RTP/AVP 8 101 19
c=IN IP4 X.X.X.X
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
*Apr 12 14:32:04.375: //528456/956488000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
From: "Jaffar AlMoosa"<sip:XXXXXXX@X.X.X.X>;tag=A953444-DE8
CSeq: 101 INVITE
Content-Length: 0
*Apr 12 14:32:05.255: //528456/956488000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 488 Not Acceptable Here
Record-Route: <sip:X.X.X.X:5060;transport=udp;lr>
To: <sip:8007490000@X.X.X.X>;tag=sbc0804tf2pc227
CSeq: 101 INVITE
Reason: Q.850;cause=65;text="bearer capability not implemented"
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
Thank you,
Shadi
5 Replies 5
Shadi Shami
Level 7
Level 7
Looking into this one.
Sent:
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 68
Content-Length: 271
v=0
s=SIP Call
c=IN IP4 X.X.X.X
t=0 0
c=IN IP4 X.X.X.X
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
CSeq: 101 INVITE
Content-Length: 0
Thank you,
Shadi
But stc is saying pbx problem. I also tested with pri its working fine. You have ttranscoder configured?
I worked with them a lot and they never said the problem from their side :)
No need to xcoder as we alrerady send the codec they prefer (g711alaw).
Referring to the log file STC provided (traces_ngn-sx-mat-108_sip_2015-04-12-09-36-10.txt) from their proxy server, it's appearing clearly they are disconnecting the call with (488 Not Acceptable Here), so they have to explain why the y disconnecting the call and why other toll free numbers working fine except for this specific one.
Thank you,
Shadi
Thanks for your help
