12-26-2023 04:39 AM
Kindly advise if SM-X-8FXS/12FXO in C8300-2N2S-6T has 12 FXO ports inbuilt or we need to order 3 NIM-4FXO with each service module. Hence to connect 32 PSTN, we would need two SM-X-8FXS/12FXO with 3*2=6 NIM-4FXO to provide 24 FXO ports and then add 2 NIM-4FXO in the 2 NM to provide 8 FXO thereby providing 24+8=32 FXO ports for PSTN?
12-26-2023 05:37 AM
Since you are upgrading new platform, why not ask Telco Vendor to Deliver E1 Lines rather OLD FXO ports ?
12-26-2023 05:41 AM
12-26-2023 08:23 AM
not sure costing wise, any way 24+8 can do the work, since you are blocking the module, in case any port go bad you do not have redundancy, if i were you i go with 24+16 here for redundancy.
also check in the datasheet any limitation :
