05-08-2014 12:31 AM - edited 03-16-2019 10:43 PM
Hello!
This can be very stupid question, but I can't find any info.
881-V description says :
(FXO) port for public-switched-telephone-network (PSTN) fallback
Is it possible to use it for pstn-voip gateway purposes as any other cisco or any restrictions?
Thank you!
Solved! Go to Solution.
05-09-2014 11:15 PM
Yes it can be used as a Voice gateway . Look at this :-
http://www.cisco.com/c/en/us/products/collateral/routers/887-integrated-services-router-isr/data_sheet_c78_459542.html
Hope this helps!
Karthik Sivaram
05-12-2014 02:48 AM
Yes that is right similar to other voice gateways...
05-09-2014 11:15 PM
Hope this helps!
Karthik Sivaram
05-11-2014 08:46 PM
Thank you!
05-12-2014 12:57 AM
by the way, I readed link you provided and there is only info about
no info about using FXO for gateway purposes... :-(
05-12-2014 01:43 AM
look at Table 8 in the same doc under feature " Cisco Voice Gateway" that is where you need to look
05-12-2014 02:03 AM
thank you!
so, to be completely sure, FXO port in 881-V has the same functionality as in, let's say, 1760, right?
05-12-2014 02:48 AM
