dm Beginner
Beginner
881-v as pstn(fxo)-voip gateway?
Hello!
This can be very stupid question, but I can't find any info.
881-V description says :
(FXO) port for public-switched-telephone-network (PSTN) fallback
Is it possible to use it for pstn-voip gateway purposes as any other cisco or any restrictions?
Thank you!
2 ACCEPTED SOLUTIONS
Enthusiast
Hello,Yes it can be used as a
Yes it can be used as a Voice gateway . Look at this :-
http://www.cisco.com/c/en/us/products/collateral/routers/887-integrated-services-router-isr/data_sheet_c78_459542.html
Hope this helps!
Karthik Sivaram
Highlighted
Enthusiast
Yes that is right similar to
Yes that is right similar to other voice gateways...
6 REPLIES 6
Enthusiast
Hope this helps!
Karthik Sivaram
dm Beginner
Beginner
Thank you!
Thank you!
dm Beginner
Beginner
by the way, I readed link you
by the way, I readed link you provided and there is only info about
no info about using FXO for gateway purposes... :-(
Enthusiast
look at Table 8  in the same
look at Table 8  in the same doc   under feature  " Cisco Voice Gateway" that is where you need to look
dm Beginner
Beginner
thank you! so, to be
thank you!
 so, to be completely sure, FXO port in 881-V has the same functionality as in, let's say, 1760, right?
Highlighted
Enthusiast
Content for Community-Ad
July's Community Spotlight Awards
