06-29-2017 09:30 AM - edited 03-17-2019 10:41 AM
i'm having an issue with an 8811 registering to CME11.0 on 2901 ISR
Jun 29 16:26:06.346: TFTP: Looking for SEP00425AC77B79.cnf.xml.sgn
Jun 29 16:26:07.418: TFTP: Looking for XMLDefault.cnf.xml.sgn
it is looking for the above 2 files, which don't exist
the file that is in the flash is > SEP00425AC77B79.cnf.xml
without the .sgn extension
this is the first time that i have seen this, i have another 8811 registering without issue, looking for its corresponding cnf file as cnf.xml
any help in the right direction is appreciated
Solved! Go to Solution.
06-30-2017 07:34 AM
Just do a factory reset for this phone to clear previous registration to CUCM (*.sgn file request remains from that case)
06-29-2017 01:42 PM
Please share the output of the following:
show run
show voice register tftp-bind
more system:/cme/sipphone/SIPXXXXXXXXXXXX.cnf (Note: X needs to replaced with the mac of the affected phone)
show voice register all
Inderpsi
06-30-2017 07:34 AM
06-30-2017 07:59 AM
Thank you for the responses.
I did factory reset initially, however this did not help. I found that the security settings had to be cleared manually in the phone itself. Once this was done the phone registered immediately.
Lots of wasted time factory reset does not always clear everything. My suspicions were that this phone was previously used in cucm deployment
Thank you.
06-30-2017 08:11 AM
Good, I've faced with the same case but I did FW upgrade after factory reset, that's the different.
Best regards.
06-30-2017 08:17 AM
Thing is, it would not take the fw upgrade. I assume due to the security being set.
