8821 SSID naming problem
Johan Sjögren
I'm failing to connect my 8821 to our SSID.
Our SSID is IPT-TD but the 8821 uses IPT~TD
When I input the "-" (dash-character) on the 8821, it uses the "~"(tilde-character) instead. The dash is nowhere to find.
It is not possible for me to change the network WLAN SSID, we need to use IPT-TD
Please advice
Johan Sjögren
This was my misstake.
The real dash was hidden under the 1 key. Not the * key that made most sence.
R0g22
Upgrade the firmware to the latest version. If it still causes issue, consider opening up a TAC case to confirm if this is a limitation or a possible defect.
Johan Sjögren
