07-12-2018 01:19 PM - edited 03-17-2019 01:11 PM
I'm using CUCM 9.1.2 and loaded the COP files for the the cisco phone models 8831 and 8821. I added both and rebooted the cluster. I see 8831 in device types but I still don't see the 8821.
Any thoughts?
Solved! Go to Solution.
07-12-2018 02:47 PM
That is NOT a DevPack, that's just a FW file.
Did you install a DevPack???
07-12-2018 02:12 PM
What is the exact CUCM release you're running and what DevPack did you install?
07-12-2018 02:18 PM
Version: 9.1.2.12901-3
Firmware: cmterm-8821-sip.11-0-4-14.k3.cop.sgn
07-12-2018 02:41 PM
The release notes are showing the device pack is compatible with 9.1(2) and I see it listed and showing active in Show > Software in OS Administration
07-12-2018 02:47 PM
07-12-2018 03:08 PM
No I missed that. Thank you
