8832 and old cucm
baselzind
Level 6
Level 6
please is cisco ip phone 8832 compatible with cucm 10.5?
Yes per this release note it is supported from 10.5.2 and onwards.
Response Signature
Response Signature
is this version "10.5.2.13901-2" considered 10.5.2?
I guess you might need to install a device pack on 10.5 CUCM
Check out the link https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix_chapter_01.html#reference_0D16F0C27D10F975AFAED0A6FE396F2...
Hope this Helps
Cheers
Rath!
***Please rate helpful posts and if applicable mark "Accept as a Solution"***
