10-28-2019 02:02 PM - edited 10-28-2019 02:03 PM
Hi, what am I doing wrong or what am I misunderstanding?
Why is my phone not honoring the nextnonce key?
If you look to the log (partial) below, you can see, that the SIP server comes back with a nextnonce value in the Authentication-Info line.
But the phone is still reregistering with the old key and going on for like 8 times until it gets back a 401 (Unauthorized) incl. a new nonce key which it uses then....
9 - Cisco Systems - Model=@MODEL@ Version=sip88xx.11-2-3MPP-398[TZ=GMT+00:00
] Mon Oct 28 16:15:24 2019
=============================================================[V08][HW ver: V31
][9]
5404 NOT Oct 28 16:18:25.939242 (18938:18998) voice- =====> Send (UDP) [123.123.123.123]:5060 SIP MSG:: REGISTER sip:test.net SIP/2.0^M
Via: SIP/2.0/UDP 192.168.88.181:5060;branch=z9hG4bK-b6da7efd^M
From: <sip:lh_buero@test.net>;tag=ccf6ba362d9fd204o0^M
To: <sip:lh_buero@test.net>^M
Call-ID: e573a730-54fa3579@192.168.88.181^M
CSeq: 21887 REGISTER^M
Max-Forwards: 70^M
Authorization: Digest username="lh_buero@test.net",realm="test.net",nonce="a7d99fb416a5ccfcc495eff4adb3f194",uri="sip:test.net",algorithm=MD5,response="2c798cc62d492fea2d5079f688204948",opaque="enRlX29wYXF1ZV8wMDAyMDAwNQ==",qop=auth,nc=00000001,cnonce="21558090"^M
Contact: <sip:lh_buero@192.168.88.181:5060>;expires=3600^M
User-Agent: Test Buero^M
Content-Length: 0^M
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER, UPDATE^M
Supported: replaces, sec-agree^M
^M
5405 NOT Oct 28 16:18:25.939266 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=721
5406 NOT Oct 28 16:18:25.939516 (18949:18949) mphone-CCallProxy_service(): [PXY]svcrecv QPE_VOIP_SEND_STATUS_MSG argc=6
5407 NOT Oct 28 16:18:26.067559 (18938:18998) voice- <===== Recv (UDP) [123.123.123.123]:5060 SIP MSG:: SIP/2.0 200 OK^M
To: <sip:lh_buero@test.net>;tag=ztesipctWAhXrl5drN*2-5-16640*gcfj.2^M
Contact: <sip:lh_buero@192.168.88.181:5060>;expires=300^M
P-Associated-URI: <sip:123488103045@test.net>^M
P-Associated-URI: <tel:123488103045>^M
P-Associated-URI: <sip:lh_buero@test.net>^M
Date: Mon, 28 Oct 2019 16:18:25 GMT^M
Authentication-Info: nextnonce="10024b2308596a55d02699c0a0400fb4",qop=auth,rspauth="0386df3cb9effdf08c9e00ab955827f3",cnonce="21558090",nc=00000001^M
Content-Length: 0^M
^M
5408 NOT Oct 28 16:18:26.067604 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=651
5500 NOT Oct 28 16:22:20.107981 (18938:18998) voice- =====> Send (UDP) [123.123.123.123]:5060 SIP MSG:: REGISTER sip:test.net SIP/2.0^M
Via: SIP/2.0/UDP 192.168.88.181:5060;branch=z9hG4bK-cff9a6ec^M
CSeq: 21888 REGISTER^M
Max-Forwards: 70^M
Authorization: Digest username="lh_buero@test.net",realm="test.net",nonce="a7d99fb416a5ccfcc495eff4adb3f194",uri="sip:test.net",algorithm=MD5,response="2d87c10671292527f42abb80ed191e35",opaque="enRlX29wYXF1ZV8wMDAyMDAwNQ==",qop=auth,nc=00000002,cnonce="21558090"^M
Content-Length: 0^M
^M
5501 NOT Oct 28 16:22:20.108003 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=721
5502 NOT Oct 28 16:22:20.108479 (18949:18949) mphone-CCallProxy_service(): [PXY]svcrecv QPE_VOIP_SEND_STATUS_MSG argc=6
5503 NOT Oct 28 16:22:20.148491 (18938:18998) voice- <===== Recv (UDP) [123.123.123.123]:5060 SIP MSG:: SIP/2.0 200 OK^M
To: <sip:lh_buero@test.net>;tag=23b6c6b420e43c67-702690312020cccb-cbsxz^M
User-Agent: ZTE-B200^M
Content-Length: 0^M
^M
5504 NOT Oct 28 16:22:20.148537 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=491
5594 NOT Oct 28 16:26:14.150816 (18938:18998) voice- =====> Send (UDP) [123.123.123.123]:5060 SIP MSG:: REGISTER sip:test.net SIP/2.0^M
Via: SIP/2.0/UDP 192.168.88.181:5060;branch=z9hG4bK-2bfe336^M
CSeq: 21889 REGISTER^M
Max-Forwards: 70^M
Authorization: Digest username="lh_buero@test.net",realm="test.net",nonce="a7d99fb416a5ccfcc495eff4adb3f194",uri="sip:test.net",algorithm=MD5,response="aa1e65d6a51afff47cc43b8e0fd737ba",opaque="enRlX29wYXF1ZV8wMDAyMDAwNQ==",qop=auth,nc=00000003,cnonce="21558090"^M
Content-Length: 0^M
^M
5595 NOT Oct 28 16:26:14.150840 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=720
5596 NOT Oct 28 16:26:14.151107 (18949:18949) mphone-CCallProxy_service(): [PXY]svcrecv QPE_VOIP_SEND_STATUS_MSG argc=6
5597 NOT Oct 28 16:26:14.189163 (18938:18998) voice- <===== Recv (UDP) [123.123.123.123]:5060 SIP MSG:: SIP/2.0 200 OK^M
To: <sip:lh_buero@test.net>;tag=5b8f217cd25a685-2db63fb21d1cac0e-cbsxz^M
Content-Length: 0^M
^M
5598 NOT Oct 28 16:26:14.189207 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=489
5682 NOT Oct 28 16:30:08.215343 (18938:18998) voice- =====> Send (UDP) [123.123.123.123]:5060 SIP MSG:: REGISTER sip:test.net SIP/2.0^M
Via: SIP/2.0/UDP 192.168.88.181:5060;branch=z9hG4bK-45e91ee2^M
CSeq: 21890 REGISTER^M
Max-Forwards: 70^M
Authorization: Digest username="lh_buero@test.net",realm="test.net",nonce="a7d99fb416a5ccfcc495eff4adb3f194",uri="sip:test.net",algorithm=MD5,response="4c8a9959aa87da102f22eca24ffb28b9",opaque="enRlX29wYXF1ZV8wMDAyMDAwNQ==",qop=auth,nc=00000004,cnonce="21558090"^M
Content-Length: 0^M
^M
5683 NOT Oct 28 16:30:08.215366 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=721
5684 NOT Oct 28 16:30:08.215669 (18949:18949) mphone-CCallProxy_service(): [PXY]svcrecv QPE_VOIP_SEND_STATUS_MSG argc=6
5685 NOT Oct 28 16:30:08.250098 (18938:18998) voice- <===== Recv (UDP) [123.123.123.123]:5060 SIP MSG:: SIP/2.0 200 OK^M
To: <sip:lh_buero@test.net>;tag=676400f16c7c6ceb-10ad1d8d3084c614-cbsxz^M
Content-Length: 0^M
^M
5686 NOT Oct 28 16:30:08.250145 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=491
5775 NOT Oct 28 16:34:02.252669 (18938:18998) voice- =====> Send (UDP) [123.123.123.123]:5060 SIP MSG:: REGISTER sip:test.net SIP/2.0^M
Via: SIP/2.0/UDP 192.168.88.181:5060;branch=z9hG4bK-38239292^M
CSeq: 21891 REGISTER^M
Max-Forwards: 70^M
Authorization: Digest username="lh_buero@test.net",realm="test.net",nonce="a7d99fb416a5ccfcc495eff4adb3f194",uri="sip:test.net",algorithm=MD5,response="31d83abc15ac2711fcfa6b9ae86cf533",opaque="enRlX29wYXF1ZV8wMDAyMDAwNQ==",qop=auth,nc=00000005,cnonce="21558090"^M
Content-Length: 0^M
^M
5776 NOT Oct 28 16:34:02.252694 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=721
5777 NOT Oct 28 16:34:02.252962 (18949:18949) mphone-CCallProxy_service(): [PXY]svcrecv QPE_VOIP_SEND_STATUS_MSG argc=6
5778 NOT Oct 28 16:34:02.291108 (18938:18998) voice- <===== Recv (UDP) [123.123.123.123]:5060 SIP MSG:: SIP/2.0 200 OK^M
To: <sip:lh_buero@test.net>;tag=44185761ab88e85-4b0c68293965123-cbsxz^M
Content-Length: 0^M
^M
5779 NOT Oct 28 16:34:02.291153 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=489
6150 NOT Oct 28 16:37:56.315013 (18938:18998) voice- =====> Send (UDP) [123.123.123.123]:5060 SIP MSG:: REGISTER sip:test.net SIP/2.0^M
Via: SIP/2.0/UDP 192.168.88.181:5060;branch=z9hG4bK-f66c8e10^M
CSeq: 21892 REGISTER^M
Max-Forwards: 70^M
Authorization: Digest username="lh_buero@test.net",realm="test.net",nonce="a7d99fb416a5ccfcc495eff4adb3f194",uri="sip:test.net",algorithm=MD5,response="6b28cec9ab9c65d78fbf21e5f02ba982",opaque="enRlX29wYXF1ZV8wMDAyMDAwNQ==",qop=auth,nc=00000006,cnonce="21558090"^M
Content-Length: 0^M
^M
6151 NOT Oct 28 16:37:56.315036 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=721
6152 NOT Oct 28 16:37:56.315336 (18949:18949) mphone-CCallProxy_service(): [PXY]svcrecv QPE_VOIP_SEND_STATUS_MSG argc=6
6153 NOT Oct 28 16:37:56.351953 (18938:18998) voice- <===== Recv (UDP) [123.123.123.123]:5060 SIP MSG:: SIP/2.0 200 OK^M
To: <sip:lh_buero@test.net>;tag=30984d9722a43127-3b4aa2865152e8e8-cbsxz^M
Content-Length: 0^M
^M
6154 NOT Oct 28 16:37:56.351998 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=491
6274 NOT Oct 28 16:41:50.354074 (18938:18998) voice- =====> Send (UDP) [123.123.123.123]:5060 SIP MSG:: REGISTER sip:test.net SIP/2.0^M
Via: SIP/2.0/UDP 192.168.88.181:5060;branch=z9hG4bK-1934f416^M
CSeq: 21893 REGISTER^M
Max-Forwards: 70^M
Authorization: Digest username="lh_buero@test.net",realm="test.net",nonce="a7d99fb416a5ccfcc495eff4adb3f194",uri="sip:test.net",algorithm=MD5,response="a79ff985f863b995b224a5dd264650ae",opaque="enRlX29wYXF1ZV8wMDAyMDAwNQ==",qop=auth,nc=00000007,cnonce="21558090"^M
Content-Length: 0^M
^M
6275 NOT Oct 28 16:41:50.354097 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=721
6276 NOT Oct 28 16:41:50.354364 (18949:18949) mphone-CCallProxy_service(): [PXY]svcrecv QPE_VOIP_SEND_STATUS_MSG argc=6
6277 NOT Oct 28 16:41:50.392590 (18938:18998) voice- <===== Recv (UDP) [123.123.123.123]:5060 SIP MSG:: SIP/2.0 200 OK^M
To: <sip:lh_buero@test.net>;tag=67edc16b3bf081da-7d3dca2c712c2644-cbsxz^M
Content-Length: 0^M
^M
6278 NOT Oct 28 16:41:50.392634 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=491
6371 NOT Oct 28 16:45:44.422250 (18938:18998) voice- =====> Send (UDP) [123.123.123.123]:5060 SIP MSG:: REGISTER sip:test.net SIP/2.0^M
Via: SIP/2.0/UDP 192.168.88.181:5060;branch=z9hG4bK-899db136^M
CSeq: 21894 REGISTER^M
Max-Forwards: 70^M
Authorization: Digest username="lh_buero@test.net",realm="test.net",nonce="a7d99fb416a5ccfcc495eff4adb3f194",uri="sip:test.net",algorithm=MD5,response="ac8fec08563bada8d678e91e39517c5b",opaque="enRlX29wYXF1ZV8wMDAyMDAwNQ==",qop=auth,nc=00000008,cnonce="21558090"^M
Content-Length: 0^M
^M
6372 NOT Oct 28 16:45:44.422274 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=721
6373 NOT Oct 28 16:45:44.422570 (18949:18949) mphone-CCallProxy_service(): [PXY]svcrecv QPE_VOIP_SEND_STATUS_MSG argc=6
6374 NOT Oct 28 16:45:44.463505 (18938:18998) voice- <===== Recv (UDP) [123.123.123.123]:5060 SIP MSG:: SIP/2.0 200 OK^M
To: <sip:lh_buero@test.net>;tag=3d5bf2742d7c6299-109a29072e2c1d54-cbsxz^M
Content-Length: 0^M
^M
6375 NOT Oct 28 16:45:44.463556 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=491
6462 NOT Oct 28 16:49:38.465693 (18938:18998) voice- =====> Send (UDP) [123.123.123.123]:5060 SIP MSG:: REGISTER sip:test.net SIP/2.0^M
Via: SIP/2.0/UDP 192.168.88.181:5060;branch=z9hG4bK-b8f77203^M
CSeq: 21895 REGISTER^M
Max-Forwards: 70^M
Authorization: Digest username="lh_buero@test.net",realm="test.net",nonce="a7d99fb416a5ccfcc495eff4adb3f194",uri="sip:test.net",algorithm=MD5,response="3a51e1bad46fa7d5cf65c1c3cd4410a6",opaque="enRlX29wYXF1ZV8wMDAyMDAwNQ==",qop=auth,nc=00000009,cnonce="21558090"^M
Content-Length: 0^M
^M
6463 NOT Oct 28 16:49:38.465717 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=721
6464 NOT Oct 28 16:49:38.466068 (18949:18949) mphone-CCallProxy_service(): [PXY]svcrecv QPE_VOIP_SEND_STATUS_MSG argc=6
6465 NOT Oct 28 16:49:38.584174 (18938:18998) voice- <===== Recv (UDP) [123.123.123.123]:5060 SIP MSG:: SIP/2.0 401 Unauthorized^M
To: <sip:lh_buero@test.net>;tag=ztesipxX1ze4LR-36PXE4No8Xao*2-5-16648*djdc.2^M
WWW-Authenticate: Digest realm="test.net",domain="sip:lnz.xy.test.net",nonce="5dc846aa0987e56d53cd74932cfb77f3",opaque="enRlX29wYXF1ZV8wMDAyMDAwNQ==",stale=TRUE,algorithm=MD5,qop="auth"^M
Content-Length: 0^M
^M
6466 NOT Oct 28 16:49:38.584219 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=517
6473 NOT Oct 28 16:49:38.595850 (18938:18998) voice- =====> Send (UDP) [123.123.123.123]:5060 SIP MSG:: REGISTER sip:test.net SIP/2.0^M
Via: SIP/2.0/UDP 192.168.88.181:5060;branch=z9hG4bK-60ba1660^M
CSeq: 21896 REGISTER^M
Max-Forwards: 70^M
Authorization: Digest username="lh_buero@test.net",realm="test.net",nonce="5dc846aa0987e56d53cd74932cfb77f3",uri="sip:test.net",algorithm=MD5,response="f2313a68edea5f95693be7bbaefda863",opaque="enRlX29wYXF1ZV8wMDAyMDAwNQ==",qop=auth,nc=00000001,cnonce="4bd15fa6"^M
Content-Length: 0^M
^M
6474 NOT Oct 28 16:49:38.595874 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=721
6475 NOT Oct 28 16:49:38.596124 (18949:18949) mphone-CCallProxy_service(): [PXY]svcrecv QPE_VOIP_SEND_STATUS_MSG argc=6
6476 NOT Oct 28 16:49:38.754182 (18938:18998) voice- <===== Recv (UDP) [123.123.123.123]:5060 SIP MSG:: SIP/2.0 200 OK^M
To: <sip:lh_buero@test.net>;tag=ztesipb4ccO1ViQUxYr*2-5-16640*djdg.2^M
Date: Mon, 28 Oct 2019 16:49:38 GMT^M
Authentication-Info: nextnonce="3290d77bad74d371df84dfc567bf5e9b",qop=auth,rspauth="7c69990a02384b9177981629e5981650",cnonce="4bd15fa6",nc=00000001^M
Content-Length: 0^M
^M
6477 NOT Oct 28 16:49:38.754228 (18938:18998) voice-::End-Of-Sip-Message:: SIP MSG len=652
10-28-2019 04:09 PM
I would suggest you raise a case with TAC. I don't think there is a config which controls this.
11-03-2019 12:43 PM - edited 11-03-2019 12:50 PM
No contract > no TAC, thats the problem here.
But what could be the reason Cisco did not implement this feature?
IETF says: If nextnonce is present, it must be used...
11-05-2019 08:16 AM - edited 11-08-2019 08:06 AM
nextnonce probably is not being used. I would suggest raising a case with TAC to get this looked into.
11-08-2019 08:11 AM
From the RFC 2617:
3.2.3 The Authentication-Info Header
The value of the nextnonce directive is the nonce the server wishes the client to use for a future authentication response. The server may send the Authentication-Info header with a nextnonce field as a means of implementing one-time or otherwise changing nonces. If the nextnonce field is present the client SHOULD use it when constructing the Authorization header for its next request. Failure of the client to do so may result in a request to re-authenticate from the server with the "stale=TRUE".
So it's not mandatory to use it according to the RFC.
11-12-2019 01:21 AM
Does it mean, that there is no intention from Cisco to fix it?
11-12-2019 08:38 AM
You will have to contact TAC to get this added to the list of features which need to be added. Once they get a request in it should get scheduled for an upcoming release.
Thanks.
11-12-2019 12:39 PM - edited 11-13-2019 12:07 PM
Sorry, no service-contract at our side. > No TAC.
I need to find somebody with a contract to bring the issue up for me.
