03-18-2015 11:34 AM - edited 03-17-2019 02:22 AM
Any special syntax to get the background image field to pull an image? This setting is on the body of the phone in call manager close to the bottom. Assuming that is what this field is for. For example I tried with one of the stock images /Desktops/800x480x24/syn_wallpaper_05.png but it did not make any changes to the phone.
Alex
Solved! Go to Solution.
03-19-2015 08:01 AM
We had the same problem. To resolve it, we unchecked the option "enable end user to access phone background", under -> Device -> Device settings -> common phone profile.
!!!!!! Just an fyi, all phones using that specific profile restarted when we changed this parameter. All connected calls were dropped!! !!!!!
If this helps, please rate.
03-18-2015 12:08 PM
Assuming the image aligns with the settings for the particular phone model, and is in the right directory in the TFTP server, all you need is name.png
03-18-2015 12:45 PM
Unfortunately that also did not work. syn_wallpaper_02.png which is a background that came with the firmware and is on the correct TFTP and select-able from the phone UI.
03-18-2015 12:46 PM
Let's start with this, if you try to change it manually, does it work???
03-18-2015 12:47 PM
Yes it does.
03-19-2015 08:01 AM
03-19-2015 09:37 AM
We have around 10,000 devices (phones, gateways, trunks....) associated with that profile. Thank you for the heads up that would have been hard to talk my way out of. I will see if I can get someone to sign off on me testing this after hours.
03-21-2015 08:46 PM
Hey Alex,
Have you made the change?
If so, did it resolve your issue?
Did your phones restart and active calls drop?
I was surprised the active calls were dropped within our network, when the change was made to the phone profile. Never a good thing. (:
03-30-2015 12:29 PM
I was able to verify what you said is correct. I have not changed the setting on the default profile though as I did not want to risk bringing everything down.
Thanks!
03-31-2015 12:22 PM
The actual change/save should have not restarted/reset any devices unless "Apply Config", or "Restart/Reset" was used.
The best way to pilot changes of this nature is to copy out the common phone profile and manually set the copied profile to a single test phone first.
If the common phone profile was linked to a gateway and then subsequently reset, this would cause problems with call drops.
To avoid issues like this (dropped calls as a result of common phone profile restart/reset), avoid reliance on using the default (or a single) common phone profile for gateways/trunks and phones.
02-22-2017 09:07 AM
Has anyone successfully done this similar process with a EX Series model?
