01-03-2016 05:27 AM - edited 03-17-2019 05:23 AM
I have CUCM 9.1 and Cisco IP Phones 8841. Before adding the phones to CUCM I can see the options of Ringtones. After adding the phones to CUCM no Ringtones option in setting menu. Any help?
I did not add any ringtone, I just want to see the default ringtones.
01-05-2016 01:44 AM
Thank you too much for your usual support.
I will try to upgrade the firmware first.
One question, How I can know the phones that use Ringlist-wb.xml? I just want to estimate the number of devices.
01-05-2016 04:34 AM
This information is not available, generally the 7900 series phones use the normal Ringlist.xml, the 8800 models that you are using tend to use the Ringlist-wb.xml as it supports wideband.
Manish
03-11-2019 12:05 AM
Hi Manish,
We are facing the same issue on 12.0.1.22900-11, getting only the default ringtone.
I've checked the Ringlist-wb.xml on TFTP
admin:file view tftp Ringlist-wb.xml
<CiscoIPPhoneRingList>
<Ring>
<DisplayName>Ascent</DisplayName>
<FileName>Ascent.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Calculation</DisplayName>
<FileName>Calculation.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Delight</DisplayName>
<FileName>Delight.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Evolve</DisplayName>
<FileName>Evolve.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Mellow</DisplayName>
<FileName>Mellow.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Mischief</DisplayName>
<FileName>Mischief.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Playful</DisplayName>
<FileName>Playful.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Reflections</DisplayName>
<FileName>Reflections.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Ringer</DisplayName>
<FileName>Ringer.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Ripples</DisplayName>
<FileName>Ripples.rwb</FileName>
</Ring>
<Ring>
<DisplayName>Vibes</DisplayName>
<FileName>Vibes.rwb</FileName>
</Ring>
</CiscoIPPhoneRingList>
Same is available on GUI as well.
Phone firmware : sip88xx. 12-1-1SR1-4
Settings Access is also enabled.
