2420
Participant
Thank you too much for your
Thank you too much for your usual support.
I will try to upgrade the firmware first.
One question, How I can know the phones that use Ringlist-wb.xml? I just want to estimate the number of devices.
This information is not available, generally the 7900 series phones use the normal Ringlist.xml, the 8800 models that you are using tend to use the Ringlist-wb.xml as it supports wideband.
Manish
Re: Hi,
Hi Manish,
We are facing the same issue on 12.0.1.22900-11, getting only the default ringtone.
I've checked the Ringlist-wb.xml on TFTP
admin:file view tftp Ringlist-wb.xml
<CiscoIPPhoneRingList>
        <Ring>
                <DisplayName>Ascent</DisplayName>
                <FileName>Ascent.rwb</FileName>
        </Ring>
        <Ring>
                <DisplayName>Calculation</DisplayName>
                <FileName>Calculation.rwb</FileName>
        </Ring>
        <Ring>
                <DisplayName>Delight</DisplayName>
                <FileName>Delight.rwb</FileName>
        </Ring>
        <Ring>
                <DisplayName>Evolve</DisplayName>
                <FileName>Evolve.rwb</FileName>
        </Ring>
        <Ring>
                <DisplayName>Mellow</DisplayName>
                <FileName>Mellow.rwb</FileName>
       </Ring>
        <Ring>
                <DisplayName>Mischief</DisplayName>
                <FileName>Mischief.rwb</FileName>
        </Ring>
    <Ring>
        <DisplayName>Playful</DisplayName>
        <FileName>Playful.rwb</FileName>
    </Ring>
    <Ring>
        <DisplayName>Reflections</DisplayName>
        <FileName>Reflections.rwb</FileName>
    </Ring>
    <Ring>
        <DisplayName>Ringer</DisplayName>
        <FileName>Ringer.rwb</FileName>
    </Ring>
    <Ring>
        <DisplayName>Ripples</DisplayName>
        <FileName>Ripples.rwb</FileName>
    </Ring>
    <Ring>
        <DisplayName>Vibes</DisplayName>
        <FileName>Vibes.rwb</FileName>
    </Ring>
</CiscoIPPhoneRingList>
Same is available on GUI as well.
Phone firmware : sip88xx. 12-1-1SR1-4
Settings Access is also enabled.
Content for Community-Ad
August's Community Spotlight Awards
