11-21-2019 06:10 PM - edited 06-23-2020 12:03 AM
i have 8841 phone registered in the CUCM but i notice there is several phone that different in firmware.
why is that ?
how to resolve it ?
Actual problem is that the phone with download status fail not able to call using VOIP function. Is that related ?
Solved! Go to Solution.
12-01-2019 05:26 PM
i was able to rectified and resolved the issue by updating device pack (cmterm-devicepack11.5.1.17112-1.cop.sgn)
11-21-2019 08:04 PM
You're trying to downgrade, not upgrade, the phone might not even support that version, see a sticker on the phone or the box for the minimum version the phone can use. But no, that should not cause any issues with calls, depending on the exact issue, start by doing the basic troubleshooting for it.
12-01-2019 05:26 PM
