8841 Requested Load ID firmware?
Shanej9001
We've purchased a new Cisco 8841 phone for evaluation. I've got it up and running on the CM. I've upgraded the phones firmware to 12.1-1 SR1-4. The phone has a sticker on the bottom of it that says  SW must be 11.7 or later so I understand it can't be downgraded below that. My question is why is the Download status failed and the requested load ID 10-2-2-16? The inactive load is 11-7-1-17. I've uploaded the 12.1 to the CM and restarted the TFP service. We only have one CM. Our CM version is 10.5.2. Is there something I should do to fix this? The phone is showing active and trusted.
Phone Configuration
Registration: Registered with Cisco Unified Communications Manager 172.X.X.X
IPv4 Address: 172.X.X.X
Active Load ID: sip88xx.12-1-1SR1-4
Inactive Load ID: sip88xx.11-7-1-17
Download Status: Failed
Requested Load ID: sip88xx.10-2-2-16
Download Server: 172.X.X.X
Inactive Load Failure Reason Internal Phone Error
Xavier McKinzie
How did you upgrade the phones? That version of firmware for those phones was the base firmware of an older devicepack (https://www.cisco.com/web/software/282074299/124017/cmterm-devicepack10.5.2_12014-1_Release_Notes.pdf)
I suggest following the install guide for updating the phones via the device packs: https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/Devpacks_admin/CMDP_BK_CD82F19C_00_cisco-unified-communications-manager-device.html
Xavier McKinzie
I just updated the firmware for that specific phone. I didn't update the device pack. I didn't want to upgrade the rest of my phones. I have a bunch of 7942,7945 and 7965 phones. I'm guessing I should upgrade the device pack to 10.5.2. on the CM?
I uploaded the CM device update pack to the CM server as per the instructions. I rebooted the phone and it upgraded and now the inactive load id message is gone. Everything looks good! Thank you!
