05-15-2015 12:38 AM - edited 03-17-2019 03:01 AM
I try add the 8841 SIP phone to the CME with fast-track mode. But the phone still prompted "unprovisioned"
Anything i am missing? Since i can't found any reference about the 8841 fast-track configuration. There is the CME configuration.
IOS version 15.4
voice register pool-type 8841
xml-config maxNumCalls 4
xml-config busyTrigger 2
phoneload-support
telnet-support
num-lines 6
description test_8841
reference-pooltype 9971
voice register global
mode cme
source-address 172.17.152.129 port 5060
max-dn 20
max-pool 10
authenticate register
create profile sync 0305300840135259
voice register pool 1
busy-trigger-per-button 1
id mac BCC4.93A4.66D3
type 8841
number 1 dn 1
username test password test
11-17-2015 09:13 AM
It still seems like I'm missing some files, and I'm not sure how to generate the CTL and ITL files in CME.
11-17-2015 10:12 AM
Also 400 error is for Refer request, however we were unable see an register message from phone. From last tftp debug it seems phone do not like something in configuration file, hence downloads it again and again. It would be with to open config file n have a look. You can open it with "more flash0:/config-file name", paste output here. Also you may want to remove locale command for UK from voice register global, as tftp do not have this file.
