8845 / 8865 Wall Mount - Photo Request
Alex Rich
We are considering purchasing 8845 / 65 phones. Our only hold up is we cant seem to location a photo or the wall mount used for these phones or a photo of one mounted to a wall. Does anyone have either they could provide?
Thanks!
Manish Gogna
Hi Alex,
As per the datasheet "The two-position foot stand supports viewing angles of 35 and 50 degrees; you can remove the foot stand for wall mounting, with mounting holes located on the base of the phone"
Also, check page 10 of the following doc for more details and the pic
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cuipph/8800-series/english/Accessibility_Features/access_8800_Series.pdf
Manish
- Do rate helpful posts -
Thanks for responding. Unfortunately the pic on page 10 is for the non camera 88XX series phones. The camera models have an angeled screen and use a different mount. We want to see exactly how they mount and how far they stick out when mounted. Mainly due to this statement.
The Cisco IP Phone 8845 and 8865 Wall Mount kits are slightly larger and do not meet the 307.2 Protrusion Limits section of the Americans with Disabilities Act (ADA) ADAAG requirement for mounting a phone on the wall.
The following diagram illustrates how to attach a Cisco IP Phone 8845 and 8865 to a phone bracket.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7800-8800/english/accessories/p881_b_accessorie-guide-for-cisco-ip/p881_b_accessorie-guide-for-cisco-ip_chapter_010.html
I cannot find the wall mount (CP-8800-VID-WMK) anywhere... UGGGGH!
cadjoe
Level 5
Level 5
Just drill an 1/8" hole in the CP-8800-WMK for the 8841 / 51 / 61, and use a metal screw into the slit for the plastic stand.
I do it all the time, works fine.
