11-16-2018 11:33 AM
I just ordered a new ip phone cisco 8851 and I am testing it to see if can replace the 7965 with these, but I already have a problem that it is not upgrading. I made sure the active load is on all the servers in the cluster.
Can anyone help with this issue ?
Registration: | Registered with Cisco Unified Communications Manager xx.xx.xx.xx |
IPv4 Address: | xx.xx.xx.xx |
Active Load ID: | sip88xx.12-0-1-11 |
Inactive Load ID: | cert.os.mfg.drop |
Download Status: | Failed |
Requested Load ID: | sip88xx.10-3-1-20 |
Download Server: | xx.xx.xx.xx |
Inactive Load Failure Reason | Internal Phone Error |
Solved! Go to Solution.
11-16-2018 01:09 PM
Please correct me if I am wrong, but it looks like a downgrade and not upgrade.
In cases where a new Devices have pre-loaded a newer firmware version, than the one that CUCM runs on, the CUCM requests the phone to downgrade but this is not supported.
You may need to set as a default firmware version on the CUCM, a newer version of firmware for this speficic phone.
G
please rate, if useful
11-18-2018 01:33 PM
Hello svadmin,
If the 8851 phone came from factory with a firmware version 12, downgrading to firmware 10.3 might not be possible.
Some phone hardware revisions require certain minimum firmware versions. Minimum versions are usually found in a sticker at the back of the phone.
And why would you want to downgrade to 10.3 anyway? That's an old buggy version and you should ideally be running a version 12 firmware for all your 88XX phones.
Best Regards, Jaime.
11-16-2018 12:31 PM
Have you Restarted the TFTP Service on the CUCM Cluster?
You may check the following Procedure:
G
Please rate, if useful
11-16-2018 12:47 PM
Yes I already tried that and still didn't work.
11-16-2018 01:09 PM
G
11-17-2018 07:10 AM
11-18-2018 01:33 PM
Hello svadmin,
11-19-2018 06:51 AM
What I am really trying to do is set up a phone for MRA. I have Jabber working, but somehow the phones are not. I found this document that guide through the process https://ciscocollab.wordpress.com/2015/05/26/collab-edge-mra-for-78008800dx-series-endpoints/
However it stated that I would need public root CA certificate, but I don't have that and not sure where to get it from, any idea if I do need that and how to get it?
H
11-19-2018 07:33 AM
11-19-2018 08:14 AM
Thank you Johnathan, for the information. So I checked our expressway E and we do have the CA, so not sure why the MRA from the 8851 is not working. any idea?
