11-01-2018 12:58 PM - edited 03-18-2019 12:34 PM
I have a small problem with 8x8 , once in a while 8861 drop a call and sometimes sounds not clear
I tried to use codec G.722, G.711U and now I did change to codec G.729 hopefully it will help.
Any advice what can be?
11-01-2018 01:07 PM
What is the software version of the firmware on the phone?
Thanks.
11-01-2018 01:24 PM
Software CP-8861-3PCC Configuration Utility
sip88xx.11-2-1MPP-630.loads |
it didn't show me firmware. where I can find that?
11-01-2018 01:25 PM
11-01-2018 01:27 PM
Its most probably a known issue. You can contact 8x8 and they should provide you with a fixed firmware when they are done verifying it.
Thanks.
11-01-2018 01:29 PM
is an 8x8 firmware issue?
11-01-2018 01:34 PM
No. It would be a fix on the device. But the firmware will be verified by 8x8 before they roll it out. I would suggest you get in touch with them to get the device upgraded to the firmware with the fix.
11-02-2018 08:02 PM
Thank you.
What is the latest firmware for 8861
11-03-2018 10:29 AM
11.2.1MPP.630 is the last official release on cisco.com. You can contact 8x8 or Cisco support (TAC) to get the latest Engineering Special (ES) release which has more fixes over the last official release.
Thanks.
